Crystal Sales Order Form
We have successfully linked the POForm with other Vantage tables/fields via ODBC. I've heard of others doing the same thing with the Traveler in Vantage. You have to use a subreport to do so, and currently you also need to use the third-party Merant ODBC drivers rather than the SQL-92 drivers that come with Vantage. If you have the Merant drivers, or just want to know how it's done, I can give you more details. I have heard that the Error 599 with the SQL-92 drivers may be fixed in a future patch as the root problem has now been discovered. Whether the fix will be in Vantage 5.1 or 5.2 I don't know.
Troy Funte
Liberty Electronics
----- Original Message -----
Sent: Monday, August 26, 2002 3:26 PM
Subject: [Vantage] Re: Crystal Sales Order Form
When you say modified custom form, did you add any new tables and did
the linking...if so...can you tell me how to modify the existing
custom report to add new tables and fields from them ??
Srini
--- In vantage@y..., "Troy Funte" <tfunte@e...> wrote:
> We have modified our POForm (purchase orders) with some 'terms and
conditions' at the bottom of the form. It sounds like your terms may
be longer than ours. We have about 4 lines of text. I found it best
for our Dot Matrix printer to put the text into Four separate
formula's -- one formula per line. The text is simply in quotes in
the formula.
> Troy Funte
> Liberty Electronics
> From: rlunsf
> To: vantage@y...
> Sent: Thursday, August 22, 2002 4:47 PM
> Subject: [Vantage] Crystal Sales Order Form
> I'm not sure if this is possible, but I wanted to check with the
> experts. We have a "Standard Terms and Conditions" form that we
> print on the back of every Sales Order. Currently, we print the
> Sales Order, go to Microsoft Word and retrieve the "Standard
Terms
> and Conditions" file, and manually print it on the back of the
sales
> order. We have a copier/printer that duplexes. I would like to
> change the Sales Order form in Crystal to where it prints
> the "Standard Terms and Conditions" on the second, or back,
page.
> Does anyone else do this? Is it possible?
> Yahoo! Groups Sponsor
> ADVERTISEMENT
must have already linked your email address to a yahoo id to enable
access. )
Builder and Crystal Reports and other 'goodies', please goto:
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service.
ADVERTISEMENT
Sales Order, go to Microsoft Word and retrieve the "Standard Terms
and Conditions" file, and manually print it on the back of the sales
the "Standard Terms and Conditions" on the second, or back, page.
Add a Report footer section. Inserted the word doc as an OLE Object....
adjusting formatting if necessary. Format the footer section to have a page
break before section. Go into the printer setup inside crystal and make the
necessary adjustments to duplex print. Give it a try.
David Gartner
EPG Companies Inc.
Vantage 5.20.207, Progress 9.1c
Sent: Thursday, August 22, 2002 3:48 PM
ADVERTISEMENT
We have modified our POForm (purchase orders) with some 'terms and conditions' at the bottom of the form. It sounds like your terms may be longer than ours. We have about 4 lines of text. I found it best for our Dot Matrix printer to put the text into Four separate formula's -- one formula per line. The text is simply in quotes in the formula.
Troy Funte
Liberty Electronics
ADVERTISEMENT
We add terms to all quotes, orders, and POs. The terms are put in the
report footer with a page break before them. I leave the report header with
the terms, so the PO number, etc. is listed with the terms. We had to
schrik the font down to 6 to allow them to fit on a page. It takes a little
tweaking to get it to fit correctly, but does work very well (on a laser
printer). It forces the purchasing agent or salesperson to include the
terms on each order. At first it used a lot of extra paper, but now since
most are e-mailed in a pdf format, it doesn't cause excess paper usage.
Alex Neutgens
Controller
Circuit Check Inc.
Phone: 763.694.4110
Fax: 763.694.4151
Sent: Thursday, August 22, 2002 6:00 PM
Subject: Re: [Vantage] Crystal Sales Order Form
Troy Funte
Liberty Electronics
ADVERTISEMENT
Srini
the formula.
> Troy Funte
> Liberty Electronics
> From: rlunsf
> To: vantage@y...
Terms
sales
page.
> ADVERTISEMENT
access. )
Service.
