Dave,
That is very interesting that when you re-install the crystal runtime on the
client it resolves your issue but on the reboot of the server it comes back.
I did, in my early attempt to resolve the problem, re-install the crystal
runtime but I still ran into the problem.
Still haven't tracked it down on my side yet of what is truly happening.
Scott
Dave Olender
Sent: Wednesday, August 29, 2007 7:47 AM
Subject: [Vantage] Re: Crystal Runtime Error
Mr. Scott: We are not using Symantec, we are using MCAfee. It seems
to be comming from the server because we can repair the runtime at
the clients and everyone is ok until we reboot the server. Then
everyone gets the crystal runtime error again.
DaveO
--- In vantage@yahoogroups.com, "Scott Litzau" <scott.litzau@...>
wrote:
Yahoo! Groups Links
Scott
Dave Olender
DaveO
wrote:
>not have
> Dave,
> The problems have come back. I still have not nailed it down but it
> definitely seems like it is some conflict with a MS Patch. I did
> the problem until MS07-042, MS07-43, & MS07-046. I am looking intothese
> patches to see what they are affecting.does not
> Though I can still fix it short term by having Symantec update,
> matter if you are on as admin or the user.type of
> Are you running Symantec AV? I ask that to see if there is some
> conflict between the MS Patch and Symantec somehow.Behalf Of
> Scott
> Scott Litzaususpect malware
> Sent: Thursday, August 23, 2007 2:17 PM
> Subject: RE: [Vantage] Re: Crystal Runtime Error
> Dave,
> I have not figured out yet exactly why it is happening but I
> of some sort. The reason I suspect this is that I have opened upWindows
> Explorer on the PC and my Symantec AV installs an update but it isnot a def
> update. I really suspect it is doing a rollback of a file change itsaw was
> tampered with. We have seen messages in regards to ATL71.DLL whichis
> Microsoft's Active X Template Library. What a surprise Active Xbeing the
> target.on as
> Anyway, in order for it to be a (so far) long term fix I need to be
> admin and have it install the update. Then I log in as the user andagain it
> installs the update. So my suspicious are that it affected filesthat only
> admin as access to and files specifically for the user.Behalf Of
> Scott
> Dave OlenderR2
> Sent: Wednesday, August 22, 2007 12:48 PM
> --- In vantage@yahoogroups.com, "Scott Litzau" <scott.litzau@>
> wrote:
> > I have two PCs that as of today are getting "Invalid Crystal XI
> > Runtime" when running a Crystal report. One is the AP Invoice andCrystal
> the
> > other is the Job Traveler. Both are modified versions but we have
> been
> > running these with no issue for almost a year.
> > I have run the Repair and uninstalled and re-installed the
> > Runtime.the
> > The really wierd thing is right after I have done both of those
> they
> > can print without issue and then a little while later they get
> > error again.must have
> > Scott Litzau
> We are getting the EXACT same thing. We did apply a patch on Friday
> that brought us up to 8.00.805h and we were thinking this had
> something to do with that. However, I'm getting the same message
> whenever I try to open the file using Crystal Development. It
> appears that Uninstalling and then re-installing the runtime client
> seems to fix the problem temporarily.
> And of course Epicor support has no clue.
> If anyone else has a suggestion please feel free to "pile on".
> Thanks, DaveO
> already linked your email address to a yahoo id to enable access. )Builder and
> Crystal Reports and other 'goodies', please goto:must have
> Yahoo! Groups Links
> Crystal Reports and other 'goodies', please goto:Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
> Yahoo! Groups Links
Yahoo! Groups Links
