Crystal reports for a BOM
We have been having issues with Vantage locking up as well, every once
in a while. Users can view data but upon saving, vantage hangs. If
you let it go, it will be locked up for 30 min and then the record is
released and all the users who tried to save while it was locked will
now save. I wrote my own BOM report using SQL procedures and then
feeding the result to Crystal. We have had a call open with Vantage
since October and still haven't been able to determine what the issue
is. Another note, while records are locked, MES still operates just
fine.
Is this is issue that you are having as well?
--- In vantage@yahoogroups.com, "Hartman, Jim" <jhartman@...> wrote:
> To all who have requested copies of this report,
> We have discovered some issues related to this ODBC report. It is
> suspected that the report causes Vantage to lock up. Based on this
> issue, I will not offer the report until such time as it is eliminated
> as the suspect for these lockups.
> Jim Hartman
> Procurement Engineer
> 125 Taylor Parkway
> Archbold, Ohio 43502
> Phone: (419) 445-8915 ext. 235
> Fax: (419) 445-8113
We have created a new pick slip, and set it as the default in Vantage.
When we try to go print it, we get the error below. Now the original
pick ticket was 8.5" x 11" and the new one is 8.5" x 14". Would that
be the cause of the problem? Is there somewhere to change the page size
in Vantage? Is this an Epicor Tech Support Question?
************** Exception Text **************
System.Runtime.InteropServices.COMException (0x8002000B): Invalid index.
(Exception from HRESULT: 0x8002000B (DISP_E_BADINDEX))
at
CrystalDecisions.ReportAppServer.Controllers.PrintOutputControllerClass.
ModifyPrintOptions(PrintOptions newVal)
at
CrystalDecisions.CrystalReports.Engine.PrintOptions.set_PaperSize(PaperS
ize value)
at Epicor.Mfg.Lib.Report.EpiCrystalViewer.ShowReport()
at
System.Windows.Forms.Control.InvokeMarshaledCallbackDo(ThreadMethodEntry
tme)
at System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object
obj)
at System.Threading.ExecutionContext.runTryCode(Object userData)
at
System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteed
Cleanup(TryCode code, CleanupCode backoutCode, Object userData)
at System.Threading.ExecutionContext.RunInternal(ExecutionContext
executionContext, ContextCallback callback, Object state)
at System.Threading.ExecutionContext.Run(ExecutionContext
at
System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry
tme)
at System.Windows.Forms.Control.InvokeMarshaledCallbacks()
Matt Caldwell
Technical Support Analyst
KERUSSO
P.O. Box 32
Berryville, AR 72616
Phone: 800-424-0943 Ext. 231
Fax: 870-423-3568
Web Site: http://www.kerusso.com
CONFIDENTIALITY STATEMENT:
This message, from Kerusso Inc., contains information
which is privileged and confidential and is solely for the use of
the intended recipient. If you are not the intended recipient, be
aware that any review, disclosure, copying, distribution, or use
of the contents of this message is strictly prohibited. If you have
received this in error, please destroy it and notify us immediately
at: 800-424-0943
Mr. Matt: Have you tried setting your XP local print preferences to
8.5x14 as a default?
If not I would give that a try first.
DaveO
Vantage.
original
that
size
index.
> at
s.
> at
(PaperS
> ize value)
> at
(ThreadMethodEntry
> tme)
(Object
> obj)
> at
ed
> at
(ThreadMethodEntry
> tme)
> Matt Caldwell
> KERUSSO
> P.O. Box 32
> Fax: 870-423-3568
> at: 800-424-0943
This printer is a network share. If we print this pick slip from
Crystal, it prints fine. We cannot preview or print it from Vantage,
though.
--Matt
Of Dave Olender
Sent: Tuesday, February 05, 2008 7:23 AM
Subject: [Vantage] Re: Crystal Reports/Vantage error
DaveO
Vantage.
original
that
size
index.
> at
s.
> at
(PaperS
> ize value)
> at
(ThreadMethodEntry
> tme)
(Object
> obj)
> at
ed
> at
(ThreadMethodEntry
> tme)
> Matt Caldwell
> KERUSSO
> P.O. Box 32
> Fax: 870-423-3568
> at: 800-424-0943
Good Morning Everyone,
Has anyone seen a diagram which shows how all of the tables are related
in Epicor? I know you can go into the software and see the keys and the
tables that relate to a specific table but I am looking for a diagram.
I can believe that Epicor would not have this for their vantage product.
Can any please help me with this!
Dale Kalsow | Information Technologies Director
____________________________________________________________________
Determan Brownie, Inc. | 1241 72nd Avenue NE | Minneapolis, MN 55432
* Phone: (763) 502-9689 | * Fax: (763) 571-1789
* dale.r.kalsow@... | * http://determan.com/
"Ambition is the path to success. Persistence is the vehicle you arrive
in."
Electronic Privacy Notice. This e-mail, and any attachments, contains
information that is, or may be, covered by the Electronic Communications
Privacy Act, 18 U.S.C. 2510-2521, and is also confidential and
proprietary in nature. If you are not the intended recipient, please be
advised that you are legally prohibited from retaining, using, copying,
distributing, or otherwise disclosing this information in any manner.
Instead, please reply to the sender that you have received this
communication in error, and then immediately delete it. Thank you in
advance for your cooperation.
We are trying to create a crystal BOM report. It does not look like
any of the bom reports are crystal reports. Has anyone created a
crystal BOM report and if so how?
Thanks!
in."
Dale,
I created a crystal BOM report by using multiple instances of the BOM
file and other related files, and daisy chaining them together. In other
words by relating the child from one instance to the parent of the next
instance. This works very well going down 7 levels deep, not sure if it
will work going any deeper.
Jim Hartman
125 Taylor Parkway
Fax: (419) 445-8113
NOTICE: This communication may contain privileged or other confidential
information. If you have received it in error, please advise the sender
by reply email, fax, or collect telephone call and immediately delete
the message and any attachments without copying or disclosing the
contents. Thank you.
Of Dale R. Kalsow
Sent: Tuesday, February 05, 2008 10:34 AM
Subject: [Vantage] Crystal reports for a BOM
Thanks!
* dale.r.kalsow@... <mailto:dale.r.kalsow%40determan.com> | *
<http://console.mxlogic.com/redir/?2C-UUYYed79JdZAQsInd7bNI06xY_yHIenMTv
HTLuZQnAhNKVKDMDeFteXbxEVbK9IIcBQkXFFFLKce5N4DIpGX0Ux8YhQfVs5h-rsokUz6Hq
RebqjHnBPqbRTHCQkXFFFLKc6zASO-rdbopS4Z8-qnjh09hbkDFVEwzWRoPEq87qNd46Cy0p
30SrDUvf0srhdFECQTSjhONtNwTDw61-CpFRLz>
in."
The information transmitted is intended only for the person or entity to which it is addressed and may contain confidential and/or privileged material. Any review, retransmission, dissemination or other use of, or taking of any action in reliance upon, this information by persons or entities other than the intended recipient is prohibited. If you received this in error, please contact the sender and delete the material from your system.
Mine goes 8 levels, Jim...I could not get it to go further than that.
M. Manasa Reddy
manasa@...
P: 630-806-2000
F: 630-806-2001
Of Hartman, Jim
Sent: Tuesday, February 05, 2008 9:48 AM
Subject: RE: [Vantage] Crystal reports for a BOM
Dale,
Jim Hartman
125 Taylor Parkway
Fax: (419) 445-8113
Behalf
Of Dale R. Kalsow
Thanks!
http://determan.com/ <http://determan.com/>
in."
It is my understanding that Epicor will not give users this information.
Paul Manzi
Director Information Systems
Acceleron, Inc.
Of Dale R. Kalsow
Sent: Tuesday, February 05, 2008 10:31 AM
Subject: [Vantage] Epicor table relationships
in."
CONFIDENTIALITY NOTICE: This e-mail communication and any attachments may contain confidential and privileged information for the use of the designated recipients named above. The designated recipients are prohibited from redisplaying this information to any other party without authorization. If you are not the intended recipient, you are hereby notified that you have received this communication in error and that any review, disclosure, dissemination, distribution or copying of it or its contents is prohibited by federal or state law. If you have received this communication in error, please notify Acceleron, Inc. at 1-860-651-9333, and destroy all copies of this communication and any attachments.
You can create your own version of this using the Data Dictionary Report and
selecting Table Relationships and selecting the tables you wish to view. It
is still there in v6.1, not sure about v8.
Ted Kitch
Information Technology Manager
Astro Machine Corporation
www.astromachine.com
Paul Manzi
Sent: Tuesday, February 05, 2008 11:25 AM
Subject: RE: [Vantage] Epicor table relationships
Paul Manzi
Acceleron, Inc.
Behalf
Of Dale R. Kalsow
in."
Ted Kitch
Paul Manzi
Paul Manzi
Acceleron, Inc.
Behalf
Of Dale R. Kalsow
in."
Paul Manzi
Acceleron, Inc.
Of Dale R. Kalsow
in."
Ted Kitch
Paul Manzi
Paul Manzi
Acceleron, Inc.
Behalf
Of Dale R. Kalsow
in."
Paul Manzi
Acceleron, Inc.
Of Dale R. Kalsow
in."
Yes, the relationships report is still there.
Hmm, I wonder if one could do something similar with Visio that this gent did?
http://urlgreyhot.com/personal/publications/automating_diagrams_with_visio
Don't have Visio or I would try...
Mark W.
It would be nice to have a Visio diagram. It's so much easier to get the concepts when you view how it is working.
Debbie Smith
Argonics, Inc
Mark W.
Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now.
I wonder if you could get it to go deeper, if you used sub reports.
Bruce Butler
<mailto:bbutler@...> bbutler@...
Manasa Reddy
Sent: Tuesday, ebruary 05, 2008 10:39 AM
M. Manasa Reddy
manasa@... <mailto:manasa%40weldcoa.com>
P: 630-806-2000
F: 630-806-2001
Behalf
Of Hartman, Jim
Dale,
Jim Hartman
125 Taylor Parkway
Fax: (419) 445-8113
Behalf
Of Dale R. Kalsow
Thanks!
in."
Early on in our implementation (8.03.305K at present), I also asked
about getting just such a schema...was told that none existed outside
of the Development team @ Epicor. Given any 'spare time', I'd sure
like to build one.....using the relationships in the Data dictionary..
Gary
--- In vantage@yahoogroups.com, "Dale R. Kalsow" <dale.r.kalsow@...>
> in."
I did try to build one a while back using the Visio Reverse feature and
ODBC. It did work but was such a huge file and the formatting was so
messy I just tossed the thought aside. I just tried it again a moment
ago using the Job related tables and it did extract all the tables and
field names in a nice Entity Relationship Model format. It did not link
the tables but does provide table data with index information. I suspect
to accomplish this for the entire database would take some serious
efforts.
I used Visio 2003 Professional if you are interested.
Keith Mailloux
Ferguson Perforating
(401)941-8876
Of Gary Franks
Sent: Thursday, February 07, 2008 1:32 AM
Subject: [Vantage] Re: Epicor table relationships
Gary
related
the
product.
> * dale.r.kalsow@... | * http://determan.com/ <http://determan.com/>
arrive
> in."
Communications
be
copying,
This e-mail and any attachments may contain confidential and
privileged information. If you are not the intended recipient,
please notify the sender immediately by return e-mail, delete this
e-mail and destroy any copies. Any dissemination or use of this
information by a person other than the intended recipient is
unauthorized and may be illegal.
information.
> Paul Manzi
> Acceleron, Inc.
In 6.1 ou can ODBC into the tables used for the in built Data
dictionary.
They all start with SYSPROGRESS_
this is a full list of table.
and fields within tables.
Though i have not tried to generate a full relational diagram
I would thing that looking at the number of table and fields it
would be hard to understand.
that i did produce was an alphabetic list of all field names and the
tables they occur in.
and an access query to search for the same thing.
these let me find my way into relationships i ares of the Db i have
not explored. And when i have found tabel anmes i use the data
dictionary. I guess i could improve my access Query to did out the
Data dictionary text but life is too short, use the pre built tool.
hope this is of some use.
D
