Crystal Reports field missing-MEMO fields
Rhonda,
It's been a while since I've had to do this, but if memory serves,
after we upgraded to the Vantage 6 and started using the ODBC driver
that comes with it, there were 2 places I needed to make a change.
One was in the Data Dictionary field properties, and the other was in
the Data Dictionary -> Options -> SQL Properties -> Adjust Field
Width.
My original instructions did not include that second step, so maybe
that is where your problem lies.
HTH,
Brian Stenglein
Clow Stamping Co.
--- In vantage@yahoogroups.com, "Reilly, Rhonda" <rreilly@e...> wrote:
> Brian,
> I have change the field size of several Blob fields in vantage but I
> still can't seem to get them to work in Crystal reports. I still
don't
> see them to be able to select them. I have restarted the DB
thinking
> that would help but it doesn't. Any clue.
> Thanks
> Rhonda Reilly
> Information Resource Manager
> American Aero / Titan
> 985.893.1818
> 985.893.1879 fax
> -----Original Message-----
> From: Brian Stenglein [mailto:bstenglein@c...]
> Sent: Friday, January 30, 2004 3:22 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Crystal Reports field missing-MEMO fields
> Hey guys,
> Just wanted to remind you all of a solution I've mentioned a couple
> of times previously on this issue.
> Tech Support has instructions on changing the field size of DB
> fields. You enter the Data Dictionary of your Progress DB and
shrink
> the field size from 1000 characters to 255 and it works great in
> Crystal and Access after that.
> I've used it for VB form Character fields, I've used it for the
Order
> Header Rep List, and various other times when I've wanted to use a
> memo field in a formula or selection criteria.
> Once you get the instructions its really simple to do. Only catch
is
> you have to be the only one in the DB when you make the change.
> Really Freezing in Northern MN -32 this morning.
> HTH,
> Brian Stenglein
> Clow Stamping Co.
> --- In vantage@yahoogroups.com, Adam Ellis <aellis@s...> wrote:
> > Sorry to reply to my own post, but one more thing...
> > > One trick I have found to work around this in Crystal 8.0 and
> above is
> > > to create an SQL Expression Field like so:
> > > {fn SUBSTRING(vantage.blobfield, 1, 255)}
> > > and use *this* in your formulas. The 1 is the beginning
> character and
> > > the 255 is the ending character. This slices up the blob field
> > > nicely.
> > Note that the blob field WILL NOT show up in the field list as
you
> are
> > writing the formula...you must manually type it in. However, the
> > formual will check OK and work fine.
> > SaberLogic
must
> have already linked your email address to a yahoo id to enable
access. )
Builder
> and Crystal Reports and other 'goodies', please goto:
> <http://groups.yahoo.com/group/vantage/files/>
> _____
> Yahoo! Groups Links
> * To visit your group on the web, go to:
> * To unsubscribe from this group, send an email to:
> vantage-unsubscribe@yahoogroups.com
> <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms
of
> Service <http://docs.yahoo.com/info/terms/> .
I'm writing a CR report using the "Part" table and with among other fields,
have inserted, the "Part Description" field. Previewing the report shows
the "part description" field data, but when I use the selection expert to
filter on "part description", the "part description" field is not available
in the "report fields" and has disappeared from the Part Table fields.
Any clues as to what's happening?
Norm Watkins
Engineering Mgr.
ELECPAC
847-639-2307
Crystal will not let you perform this function (in addition to formulas) on
what they call a "blob/memo" field.
Is this because it is "memo" type and too long for Crystal to deal with? I believe it has to be truncated somehow to an acceptable length for use in functions.
-Todd C.
Sent: Friday, January 30, 2004 10:16 AM
To: Vantage@Yahoogroups. Com
Subject: [Vantage] Crystal Reports field missing
Norm Watkins
Engineering Mgr.
ELECPAC
847-639-2307
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://rd.yahoo.com/SIG=12cu35rqc/M=267637.4116732.5333197.1261774/D=egroupweb/S=1705007183:HM/EXP=1075565867/A=1945637/R=0/*http://www.netflix.com/Default?mqso=60178397&partid=4116732> click here
<http://us.adserver.yahoo.com/l?M=267637.4116732.5333197.1261774/D=egroupmail/S=:HM/A=1945637/rand=167026615>
_____
Yahoo! Groups Links
vantage-unsubscribe@yahoogroups.com <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
Norm,
Try doing a search on the Crystal website under Memo fields. A few years ago
I found an article where they created a SQL expression truncating lines
together from the original memo field. They then filtered on the SQL formula
field. I used it in a report at the time, but can't remember which one.
Frozen in Minnesota -26 below
Dan Shallbetter
States Electric.
Norm Watkins
Engineering Mgr.
ELECPAC
847-639-2307
Norm,
The part description field is a "memo" field. You are unable to use
these fields in calculation (including filters).
This is one of the most annoying issues with RB going away. That and
famous "rep" field in the order header being both an "array" and a
"memo" so you can't split out the array with Crystal. If I am mistaken
on that last one, please someone let me know and know how.
Aaron Hoyt
Hittite Microwave Corporation
Sent: Friday, January 30, 2004 11:16 AM
fields,
shows
to
available
Norm Watkins
Engineering Mgr.
ELECPAC
847-639-2307
ADVERTISEMENT
roupweb/S=1705007183:HM/EXP=1075565867/A=1945637/R=0/*http:/www.netflix.
_____
Yahoo! Groups Links
<http://docs.yahoo.com/info/terms/> Service.
My findings so far are that sorting, formulas, etc with memo fields are not
supported in CR 8.5. The search through CR Knowledge Base says "This issue
has been resolved in Crystal Reports 9".
Todd mentioned on 1/8 that CR8.5 is used with 5.2 and beyond, but is anyone
successfully using CR9?
Norm Watkins
Engineering Mgr.
ELECPAC
847-639-2307
Sent: Friday, January 30, 2004 10:25 AM
Subject: RE: [Vantage] Crystal Reports field missing
Norm,
Aaron Hoyt
fields,
shows
to
available
Norm Watkins
Engineering Mgr.
ELECPAC
847-639-2307
ADVERTISEMENT
_____
Yahoo! Groups Links
Yahoo! Groups Links
Your use of Yahoo! Groups is subject to:
Norm,
I still have not found my report using the SQL expression. I did find
Crystal KB C2009954 that might work for you. I have Crystal 9.0 loaded on my
test server. I have written only one report with it. I created two DBF
tables using the export utility in Vantage, and join them in CR9.0 without
getting the no primary index error message when I tried doing it in CR8.5.
Crystal 9.0 has a little different look and feel. Crystal 10.0 is either
just released, or soon to be. To my knowledge Epivor does not support
anything past 8.5
Dan Shallbetter
States Electric Mfg.
Sent: Friday, January 30, 2004 12:00 PM
Norm Watkins
Engineering Mgr.
ELECPAC
847-639-2307
Norm,
Aaron Hoyt
fields,
shows
to
available
Norm Watkins
Engineering Mgr.
ELECPAC
847-639-2307
< http://groups.yahoo.com/group/vantage/files/
<http://groups.yahoo.com/group/vantage/files/> >
ADVERTISEMENT
< http://rd.yahoo.com/SIG=12cu35rqc/M=267637.4116732.5333197.1261774/D=eg
<http://rd.yahoo.com/SIG=12cu35rqc/M=267637.4116732.5333197.1261774/D=eg>
< http://us.adserver.yahoo.com/l?M=267637.4116732.5333197.1261774/D=egrou
<http://us.adserver.yahoo.com/l?M=267637.4116732.5333197.1261774/D=egrou>
_____
Yahoo! Groups Links
<http://groups.yahoo.com/group/vantage/>
< http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> >
Service.
Yahoo! Groups Links
_____
Yahoo! Groups Links
Norm,
Missed the beginning of this thread, but...
> are not
> issue
One trick I have found to work around this in Crystal 8.0 and above is
and use *this* in your formulas. The 1 is the beginning character and
the 255 is the ending character. This slices up the blob field nicely.
Don't get me started on the salesrep list. Whats worse is the shop
schedule! I wrote an enhanced priority dispatch report once that was
supposed to accomodate for holidays and such. Imagine my horror when I
found that field is stored in the same manner.
HTH,
Adam Ellis <aellis@...>
SaberLogic
> nicely.
Note that the blob field WILL NOT show up in the field list as you are
SaberLogic
How do you handle shift differential, do you include it in the overtime
calculation or do you just pay the premium on all hours worked?
Kathy Hambleton
Electron Energy Corporation
Shift Differential should have overtime applied to it per Federal
requirements.
Thank you,
Carol Engen
Controller
Winona Lighting
Phone: 507-454-5113, Ext. 314
Fax: 507-454-4806
e-mail: cengen@... <mailto:cengen@...>
Sent: Friday, January 30, 2004 2:26 PM
Subject: [Vantage] Shift differential and overtime
calculations
the overtime
worked?
Kathy Hambleton
access. )
------------------------ Yahoo! Groups Sponsor
Yahoo! Groups Links
Are you sure it's a Federal requirement?
Greg Clauser
General Manager.
Lakin General Corporation
773-871-9604 fax:773-871-1265
gclauser@...
Sent: Friday, January 30, 2004 2:36 PM
Subject: RE: [Vantage] Shift differential and overtime calculations
requirements.
Thank you,
Carol Engen
Controller
Winona Lighting
Fax: 507-454-4806
calculations
the overtime
worked?
Kathy Hambleton
access. )
Yahoo! Groups Links
_____
Yahoo! Groups Links
From www.dol.gov <http://www.dol.gov> ...fact sheet #23 excerpt:
The regular rate includes all remuneration for employment except certain
payments excluded by the Act itself. Payments which are not part of the
regular rate include pay for expenses incurred on the employer's behalf,
premium payments for overtime work or the true premiums paid for work on
Saturdays, Sundays, and holidays, discretionary bonuses, gifts and payments
in the nature of gifts on special occasions, and payments for occasional
periods when no work is performed due to vacation, holidays, or illness.
I don't see where shift differential is not a part of their regular pay. I
don't think it fits their exemptions.
As always...please consult your tax advisor, attorney and all others.
Thank you,
Carol Engen
Controller
Winona Lighting
Fax: 507-454-4806
Sent: Friday, January 30, 2004 2:48 PM
To: 'vantage@yahoogroups.com'
Greg Clauser
General Manager.
gclauser@...
calculations
Federal
requirements.
Thank you,
Carol Engen
Controller
Winona Lighting
Fax: 507-454-4806
e-mail: cengen@...
<mailto:cengen@...>
[mailto:kbh@...]
overtime
calculations
include it in
the overtime
all hours
worked?
Kathy Hambleton
Hey guys,
fields. You enter the Data Dictionary of your Progress DB and shrink
I've used it for VB form Character fields, I've used it for the Order
Once you get the instructions its really simple to do. Only catch is
HTH,
Brian Stenglein
Clow Stamping Co.
above is
character and
> > nicely.
are
> SaberLogic
Carol,
Here's what I found on the DOL site:
Night Work & Shift Work
Extra pay for working night shifts is a matter of agreement between the
employer and the employee (or the employee's representative). The Fair Labor
Standards Act (FLSA) does not require extra pay for night work. However, the
FLSA does require that covered, nonexempt workers be paid not less than time
and one-half the employee's regular rate for time worked over 40 hours in a
workweek.
According to how I read this I don't think it is required to be included.
>From what you sited below I still can't figure out what is required.
Kathy Hambleton
Sent: Friday, January 30, 2004 4:08 PM
Thank you,
Carol Engen
Controller
Winona Lighting
Fax: 507-454-4806
Greg Clauser
General Manager.
gclauser@...
calculations
Federal
requirements.
Thank you,
Carol Engen
Controller
Winona Lighting
Fax: 507-454-4806
e-mail: cengen@...
<mailto:cengen@...>
[mailto:kbh@...]
overtime
calculations
include it in
the overtime
all hours
worked?
Kathy Hambleton
Yahoo! Groups Links
Now I am not sure either... I retract my opinion.
Union Contracts and States may have different guidelines from Federal...
Thank you,
Carol Engen
Controller
Winona Lighting
Fax: 507-454-4806
Sent: Friday, January 30, 2004 3:42 PM
Carol,
between the
work. However, the
not less than time
over 40 hours in a
workweek.
be included.
required.
Kathy Hambleton
calculations
excerpt:
except certain
part of the
employer's behalf,
for work on
gifts and payments
for occasional
or illness.
regular pay. I
all others.
Thank you,
Carol Engen
Controller
Winona Lighting
Fax: 507-454-4806
e-mail: cengen@...
<mailto:cengen@...>
[mailto:gclauser@...]
differential and
Greg Clauser
General Manager.
gclauser@...
[mailto:cengen@...]
and overtime
calculations
applied to it per
Federal
requirements.
Thank you,
Carol Engen
Controller
Winona Lighting
Fax: 507-454-4806
e-mail: cengen@...
<mailto:cengen@...>
[mailto:kbh@...]
2004 2:26 PM
differential and
overtime
calculations
include it in
the overtime
the premium on
all hours
worked?
Kathy Hambleton
When you have the shop employee enter his own labor into Data
Collection, how do you account for someone who is running two machines
at the same time? We believe that we are being efficient and that the
total labor of 10 hours should be divided between the two jobs at 5
hours each. Since employee punches in at real time, won't it give each
job 10 hours each? 20 hours of labor, but 10 hours to payroll.
Wondering how to go live in data collection and get off the labor card
entry.
Patty Cioffi (chofee)
Accounting Department
EFS Aerospace, Inc.
A Triumph Group Company
voice 661-295-1015 x101
fax 661-295-1058
e-mail <mailto:patty.cioffi@...> patty.cioffi@...
When they clock into multiple jobs, Vantage Data Collection automatically
splits the time between the jobs. The clock start/end times will be the same
but the labor hours are split.
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Friday, January 30, 2004 2:33 PM
Subject: RE: [Vantage] Re: Labor Collection Questions
> entry.
> EFS Aerospace, Inc.
> fax 661-295-1058
> Yahoo! Groups Links
Hi All,
We used the SQL statement workaround successfully for years. We are
upgrading from Winnt 4.0 to W2K. On the machines with W2K, crystal
(8.0) doesn't recognize the field (the one we had to type
in because it wasn't available to select) . It tells me field does
not exist!
So we are on to plan B, modifying the field size. However, the
vantage document only mentions the Character fields that may be used
for VB forms. Has anyone modified the Part Description Fields in Job
Head or Order Detail table etc?
I have lots of reports that I need to make work.... or I guess I
could rewrite them in report builder.
Any thoughts would be appreciated!
Jill Pleau
Mid-State Machine Products
--- In vantage@yahoogroups.com, "Brian Stenglein" <bstenglein@c...>
wrote:
> Hey guys,
shrink
Order
is
> HTH,
> Brian Stenglein
> Clow Stamping Co.
> above is
> character and
> > > nicely.
you
> are
> > SaberLogic
