Crystal Reports Character Field
Very, very cool! Thank you so much!
Â
Dustin Biniek
Sent: Wed, January 6, 2010 1:07:53 PM
Subject: RE: [Vantage] Crystal Reports Character Field
Â
Hi Dustin,
Try :
mid({FieldName} ,instr({FieldNam e},"StartDate" ,1)+9,10) ;
Replace the two occurrences of {FieldName} with your field name
Regards,
Linda
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
Of melissa hietala
Sent: Wednesday, January 06, 2010 1:48 PM
To: vantage@yahoogroups .com
Subject: [Vantage] Crystal Reports Character Field
Hello all,
I have a character field pulled into a crystal report. What I need to
do is create a formula that will seach for a particular string of text
within the character field. For example, it would need to locate the
string "StartDate" within the character field. I would then need the
formula to return the following 10 characters that are displayed after
the string "StartDate". Hope this makes sense. Any thoughts on how
this can be accomplished?
Dustin Biniek
DustinB@ultramc. com <mailto:DustinB% 40ultramc. com>
Hello all,
I have a character field pulled into a crystal report. What I need to do is create a formula that will seach for a particular string of text within the character field. For example, it would need to locate the string "StartDate" within the character field. I would then need the formula to return the following 10 characters that are displayed after the string "StartDate". Hope this makes sense. Any thoughts on how this can be accomplished?
Dustin Biniek
DustinB@...
First I am using instr command to find where is the search character then I am using mid command to show characters from position x and length y.
Sent: Wed, January 6, 2010 12:47:45 PM
Â
Hello all,
Dustin Biniek
Â
Hello all,
Dustin Biniek
Â
Hello all,
Dustin Biniek
Â
Hello all,
Dustin Biniek
Â
Hello all,
Dustin Biniek
Hi Dustin,
Try :
mid({FieldName},instr({FieldName},"StartDate",1)+9,10);
Regards,
Linda
Of melissa hietala
Hello all,
Dustin Biniek
DustinB@... <mailto:DustinB%40ultramc.com>
