I'm trying to insert the PODetail/POHeader table fields into this report. Need a little assistance on the steps. I'm working with the "Report Table Definitions," to try and accomplish. I've inserted the table in the definition and it populates on the XML report in Crystal, but there's no data. Not sure if a relationship is required in the definition that I'm missing.
Thanks.
Do you have a relationship defined for each new table? If so, then select each table and go to the tab shown as Excluded Fields (in 8.03.409c) and move some fields that you want to include to the left side where it shows a list of Included Report Fields.
Sent: Wednesday, July 02, 2014 3:33 PM
Subject: [Vantage] Crystal Report - Production Detail Report (PDR)
Thanks.
It also sounds like if you have groups in your report and the field you are trying to display in not in that group data, the whole document will go blank.
Miguel A. Santillan
Compass Manufacturing Systems
510-661-6666 Office
Sent: Thursday, July 03, 2014 7:39 AM
Subject: [Vantage] Re: Crystal Report - Production Detail Report (PDR)
You are saying that the table/fields appear in crystal but there is no data being displayed?
In crystal in the field explorer right click the fields you added and click 'Browse Data' this will show you the data for this field, I am assuming there is data to be displayed inside the report. If it shows data in the browse data window but is not displaying in the report then you probably have an issue with the linking in your crystal report (in crystal: Database > Database Expert > Links). If you right click and browse the data and it is blank then you may have an issue with the linking in the RDD.
Hope this helps.
From: "sanfranc415@... [vantage]" <vantage@yahoogroups.com>
Sent: Wednesday, July 2, 2014 4:33 PM
Sent: Thursday, July 3, 2014 1:58 PM
#ygrps-yiv-516466254yiv6662658345 .ygrps-yiv-516466254yiv6662658345ygrp-photo-title{
clear:both;font-size:smaller;height:15px;overflow:hidden;text-align:center;width:75px;}
#ygrps-yiv-516466254 #ygrps-yiv-516466254yiv6662658345 div.ygrps-yiv-516466254yiv6662658345ygrp-photo{
background-position:center;background-repeat:no-repeat;background-color:white;border:1px solid black;height:62px;width:62px;}
#ygrps-yiv-516466254 #ygrps-yiv-516466254yiv6662658345 div.ygrps-yiv-516466254yiv6662658345photo-title
a,
#ygrps-yiv-516466254 #ygrps-yiv-516466254yiv6662658345 div.ygrps-yiv-516466254yiv6662658345photo-title a:active,
#ygrps-yiv-516466254 #ygrps-yiv-516466254yiv6662658345 div.ygrps-yiv-516466254yiv6662658345photo-title a:hover,
#ygrps-yiv-516466254 #ygrps-yiv-516466254yiv6662658345 div.ygrps-yiv-516466254yiv6662658345photo-title a:visited {
text-decoration:none;}
#ygrps-yiv-516466254 #ygrps-yiv-516466254yiv6662658345 div.ygrps-yiv-516466254yiv6662658345attach-table div.ygrps-yiv-516466254yiv6662658345attach-row {
clear:both;}
#ygrps-yiv-516466254 #ygrps-yiv-516466254yiv6662658345 div.ygrps-yiv-516466254yiv6662658345attach-table div.ygrps-yiv-516466254yiv6662658345attach-row div {
float:left;}
#ygrps-yiv-516466254 #ygrps-yiv-516466254yiv6662658345 p {
clear:both;padding:15px 0 3px 0;overflow:hidden;}
#ygrps-yiv-516466254 #ygrps-yiv-516466254yiv6662658345 div.ygrps-yiv-516466254yiv6662658345ygrp-file {
width:30px;}
#ygrps-yiv-516466254 #ygrps-yiv-516466254yiv6662658345 div.ygrps-yiv-516466254yiv6662658345attach-table div.ygrps-yiv-516466254yiv6662658345attach-row div div a {
#ygrps-yiv-516466254 #ygrps-yiv-516466254yiv6662658345 div.ygrps-yiv-516466254yiv6662658345attach-table div.ygrps-yiv-516466254yiv6662658345attach-row div div span {
font-weight:normal;}
#ygrps-yiv-516466254 #ygrps-yiv-516466254yiv6662658345 div.ygrps-yiv-516466254yiv6662658345ygrp-file-title {
font-weight:bold;}
#ygrps-yiv-516466254 #ygrps-yiv-516466254yiv6662658345 #ygrps-yiv-516466254yiv6662658345 –
#ygrps-yiv-516466254yiv6662658345ygrp-mkp {
border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-516466254 #ygrps-yiv-516466254yiv6662658345 #ygrps-yiv-516466254yiv6662658345ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-516466254 #ygrps-yiv-516466254yiv6662658345 #ygrps-yiv-516466254yiv6662658345ygrp-mkp #ygrps-yiv-516466254yiv6662658345hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-516466254 #ygrps-yiv-516466254yiv6662658345 #ygrps-yiv-516466254yiv6662658345ygrp-mkp #ygrps-yiv-516466254yiv6662658345ads {
margin-bottom:10px;}
#ygrps-yiv-516466254 #ygrps-yiv-516466254yiv6662658345 #ygrps-yiv-516466254yiv6662658345ygrp-mkp .ygrps-yiv-516466254yiv6662658345ad {
padding:0 0;}
#ygrps-yiv-516466254 #ygrps-yiv-516466254yiv6662658345 #ygrps-yiv-516466254yiv6662658345ygrp-mkp .ygrps-yiv-516466254yiv6662658345ad p {
margin:0;}
#ygrps-yiv-516466254 #ygrps-yiv-516466254yiv6662658345 #ygrps-yiv-516466254yiv6662658345ygrp-mkp .ygrps-yiv-516466254yiv6662658345ad a {
color:#0000ff;text-decoration:none;}
Thanks for all the feedback. I’ve already added the table and relationships, but not sure what relationships are required to have the PONum show up on the PDR?
