Ok, once I selected the different printer it gave me different page size options. I just went in and created a new page format for the printer and it worked perfectly.
Thanks, everyone, for your help.
Aaron
Aaron
--- In vantage@yahoogroups.com, "Vic Drecchio" <vic.drecchio@...> wrote:
> Yes, and once it readjusts itself you should see everything in Design
> mode truncated (width of form). If you get into Design mode move all
> fields within the constraints you see now and it will only print out one
> label... at least it should.
> -----Original Message-----
> Of tomrippity02
> Sent: Tuesday, July 28, 2009 5:05 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Crystal Report Labels
> Actually, it was my printing to the label printer that made me realize I
> had a problem. I assumed that when I printed it would only print to the
> necessary dimensions, but in fact, it ran off about 4 labels. 1 with
> the information on it and then 3 more blank labels that I'm assuming was
> the white space in the report.
> --- In vantage@yahoogroups.com, "Vic Drecchio" <vic.drecchio@> wrote:
> > Aaron, when you actually print to a label printer (which I'm assuming
> > you may have one connected to your PC for development) Crystal Reports
> > will auto-adjust the page settings to whatever that printer driver
> > specifies.
> > When I create my Crystal Reports labels I hook up an Intermec label
> > printer with a parallel cable to my PC. I create my label and the
> first
> > time I print to that physical printer Crystal Reports recognizes that
> > the Windows printer drivers specify a page setting of 4x6 or whatever
> > size media you are using.
> > Alternatively, I think you can go into Page Setup and also choose a
> > printer and it will auto adjust page settings.
> > Otherwise, until you print, Crystal Reports assumes 8.5x11.
> > Vic
> Behalf
> > Of tomrippity02
> > Sent: Tuesday, July 28, 2009 4:46 PM
> > I've done that and it will let me change the width, but not the
> height.
> > The height box is disabled and has a value of 0's.
> > Aaron
> > --- In vantage@yahoogroups.com, "Sean McDaniel" <smcdanie@> wrote:
> > > Right-click n the section expert. Select the details section. There
> > should
> > > be a checkbox for multiple columns. Check that. Then another tab
> will
> > show
> > > up for layout where you set this up.
> > Behalf Of
> > > tomrippity02
> > > Sent: Tuesday, July 28, 2009 4:01 PM
> > > 11.5
> > > --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
> > "Manasa
> > > Reddy" <manasa@> wrote:
> > > > What version of Crystal do you use?
> > > > M. Manasa Reddy
> > > > manasa@
> > > > P: 630-806-2000
> > > > F: 630-806-2001
> > > > ________________________________
> > > > From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > > [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ]
> > On
> > > Behalf
> > > > Of tomrippity02
> > > > Sent: Tuesday, July 28, 2009 2:44 PM
> > > > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > > > Subject: [Vantage] Crystal Report Labels
> > > > I am trying to create about 50 different labels with Crystal
> reports
> > and
> > > > BAQ. I have the information I want in the report and I have it
> > > > positioned the way I want, the problem I am having is the size of
> > the
> > > > paper. I only want to print a 3x5 label, but when I print it
> > actually
> > > > spits out 8.5x11.
> > > > Can someone tell me how I can setup the report to only print 3x5?
> > > > Thanks,
> > > > Aaron
> > > > [Non-text portions of this message have been removed]
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> > have already linked your email address to a yahoo id to enable access.
> > (1) To access the Files Section of our Yahoo!Group for Report Builder
> > and Crystal Reports and other 'goodies', please goto:
> > http://groups.yahoo.com/group/vantage/files/.
> > http://groups.yahoo.com/group/vantage/messages
> > (3) To view links to Vendors that provide Vantage services goto:
> > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> have already linked your email address to a yahoo id to enable access. )
