Crystal Report Formula
Yep I caught that as well! Thanks so much for your help!
Sent: Wed, February 16, 2011 3:49:05 PM
Subject: RE: [Vantage] Crystal Report Formula
Â
Oops! I have an extra curly bracket after the load hours:
It should be LoadHours := split({ResourceTimeUsed.LoadHours},"~");
NOT LoadHours := split({ResourceTimeUsed.LoadHours}},"~");
melissa hietala
Sent: Wednesday, February 16, 2011 4:38 PM
Subject: Re: [Vantage] Crystal Report Formula
Thank you, I will give it a shot
From: Linda Lowney <llowney@... <mailto:llowney%40pridesigns.com> >
Sent: Wed, February 16, 2011 10:18:01 AM
Something like this: (untested)
stringvar array LoadHours;
numbervar TotalHours;
numbervar i;
TotalHours = 0;
for i := 1 to ubound(LoadHours) do
TotalHours := TotalHours + tonumber(LoadHours[i])
TotalHours
[mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On Behalf
Of
melissa hietala
Sent: Tuesday, February 15, 2011 9:55 AM
Thanks for the response, Can you give me a little more info on where I need to
go from here? Maybe some sample code of what the end result may look like?
Sent: Mon, February 14, 2011 12:51:31 PM
Hi Dustin,
You can use the "Split" function in Crystal. Try:
Split(ResourceTimeUsed.LoadHours,"~")
This should load each amount into a string array.
Linda
Of melissa hietala
Sent: Monday, February 14, 2011 1:42 PM
Subject: [Vantage] Crystal Report Formula
In crystal I am trying to take the field "ResourceTimeUsed.LoadHours"
and
perform a calcuation on it.
The field is of type "string" and contains a list of #'s separted by the
symbol: Example: "4.41~10~5.01"
What I need to do is take this field and find all the #'s and add the
#'s to
get a grand total. So in the example above I would need to take 4.41 +
10 +
5.01 and return the value 19.42. The amount of #s in the "string" of
#'s
can vary, so I would need to loop through all the values in the string
regardless of how many values there are. Does anyone know how this can
be
accomplished in Crystal?
Dustin Biniek
UMC, Inc.
__________________________________________________________
TV dinner still cooling?
Check out "Tonight's Picks" on Yahoo! TV.
http://tv.yahoo.com/
In report builder, you can create a calculated field that can reference itself.
Ex.
OP1 = IIF(Count = 1, joboper.opcode, OP1)
In this example if count = 1, it would return the opcode, if count <> 1, it would return the value of OP1 it had calculated before.
How can I recreate this in Crystal Reports.
When I try the same thing, I get this error message:
"A number, currency amount, Boolean, date, time, date-time, or string is expected here."
Any ideas on how I can do this?
Jasper
I know the trick in RB is to create the calculated field as the end
character type first and save it.
Counter = 1
Not the system knows "counter" is numeric and = 1.
Then you can edit "count" and reference itself.
Counter = Counter + 1
If you just enter the end result you get an error.
Crystal may need the same process in creating variables/calculated fields
that reference themselves.
Good luck.
Patrick Winter
Sent: Wednesday, October 06, 2004 8:16 AM
To: Vantage Groups (E-mail)
itself.
Ex.
expected here."
Jasper
------------------------ Yahoo! Groups Sponsor --------------------~--> Make
a clean sweep of pop-up ads. Yahoo! Companion Toolbar.
Now with Pop-Up Blocker. Get it for free!
http://us.click.yahoo.com/L5YrjA/eSIIAA/yQLSAA/PhFolB/TM
Yahoo! Groups Links
In crystal I am trying to take the field "ResourceTimeUsed.LoadHours" and
The field is of type "string" and contains a list of #'s separted by the "~"
symbol:Â Example:Â "4.41~10~5.01"
What I need to do is take this field and find all the #'s and add the #'s to
get a grand total. So in the example above I would need to take 4.41 + 10 +
5.01 and return the value 19.42. The amount of #s in the "string" of #'s
regardless of how many values there are.  Does anyone know how this can be
Thanks, Â
Â
Dustin Biniek
UMC, Inc.
____________________________________________________________________________________
Hi Dustin,
Linda
Of melissa hietala
and
#'s to
10 +
#'s
be
Dustin Biniek
UMC, Inc.
Â
Hi Dustin,
Linda
Of melissa hietala
and
#'s to
10 +
#'s
be
Dustin Biniek
UMC, Inc.
numbervar i;
TotalHours = 0;
TotalHours
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of melissa hietala
Hi Dustin,
Linda
From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On Behalf
Of melissa hietala
and
#'s to
10 +
#'s
be
Dustin Biniek
UMC, Inc.
Â
numbervar i;
TotalHours = 0;
TotalHours
melissa hietala
Hi Dustin,
Linda
Of melissa hietala
and
#'s to
10 +
#'s
be
Dustin Biniek
UMC, Inc.
numbervar i;
TotalHours = 0;
TotalHours
From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On Behalf Of
melissa hietala
From: Linda Lowney <llowney@... <mailto:llowney%40pridesigns.com> <mailto:llowney%40pridesigns.com> >
To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
Hi Dustin,
Linda
From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
[mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On Behalf
Of melissa hietala
and
#'s to
10 +
#'s
be
Dustin Biniek
UMC, Inc.
