I ws going over one my crystal reports and made one change to it and got the following error: System error has occurred! Run in preview mode from System Monitor for details.
I tried undoing the change and it still gave the same error.
What is the error when run in preview mode?
It ran just fine. Then i downloaded it with no issues, logged out of epicor and came back in and it worked. Was getting ready to respond, but found this to be a little odd. On a side note: is it possible to add a field in crystal to the BAQResult?
You would first add the new column to the BAQ related to the BAQ report, run the report, then refresh the Crystal Report in the designer with a new xml dataset that includes the newly added column.
Gotcha. Now to find the location for the XML file. So busy today thinking is a luxury! LOL!
\\taskagentserver\epicordata\reports\[name of user executing report]
