Crystal Report Error
Has anyone gotten a Crystal Reports database error #247? It
says "ODBC error: [MERANT][ODBC PROGRESS driver][PROGRESS}**Unable to
understand after--"DECLARE".(247". What is wrong and how do I fix it?
Sonya Cover
Electron Energy
From the Crystal dropdown menus: Database, Show SQL Query, Reset. Then Go
back to the Show SQL Query and from the FROM part of the SQL remove the
leading "(" between oj and vantage then remove the same amount of trailing
")". Always remove the same amount of parenthesis.
Tom Borgenheimer
Quality Engineer
Circuit Check, Inc.
763-694-4133
<CUT>
FROM
{ oj ((((vantage.RMAHead RMAHead INNER JOIN vantage.Customer Customer ON
RMAHead.Company = Customer.Company AND
RMAHead.CustNum = Customer.CustNum)
INNER JOIN vantage.RMADtl RMADtl ON
RMAHead.Company = RMADtl.Company AND
RMAHead.RMANum = RMADtl.RMANum)
INNER JOIN vantage.OrderDtl OrderDtl ON
RMADtl.Company = OrderDtl.Company AND
RMADtl.OrderNum = OrderDtl.OrderNum AND
RMADtl.OrderLine = OrderDtl.OrderLine)
INNER JOIN vantage.Reason Reason ON
RMADtl.Company = Reason.Company AND
RMADtl.ReturnReasonCode = Reason.ReasonCode)
INNER JOIN vantage.OrderHed OrderHed ON
OrderDtl.Company = OrderHed.Company AND
OrderDtl.OrderNum = OrderHed.OrderNum}
WHERE
OrderHed.EntryPerson = '12270'
ORDER BY
Reason.Description ASC,
Customer.Name ASC,
RMAHead.RMADate DESC
Sent: Thursday, November 08, 2001 2:31 PM
Subject: [Vantage] Crystal Report Error
Sonya Cover
Electron Energy
Tom, I did try your suggestion but it didn't work. I still got the same
message
Sonya
From: Tom Borgenheimer [mailto:tom.borgenheimer@...]
Sent: Thursday, November 08, 2001 3:59 PM
Subject: RE: [Vantage] Crystal Report Error
Tom Borgenheimer
Quality Engineer
Circuit Check, Inc.
763-694-4133
<CUT>
FROM
WHERE
ORDER BY
Customer.Name ASC,
Sonya Cover
Electron Energy
<http://www.progress.com/media/general/spaces/clear.gif>
From Progress Knowledgebase:
Kbase Id:
<http://www.progress.com/media/general/spaces/clear.gif> 20071
Title:
<http://www.progress.com/media/general/spaces/clear.gif> Error 247
Using Crystal Reports via ODBC Driver
Creation:
<http://www.progress.com/media/general/spaces/clear.gif> 23-Aug-2000
Modified:
SUMMARY
This solution provides a workaround to the following error message
that can occur as you as you generate a report using Crystal Reports
7.0 and connect to a Progress Database via a MERANT ODBC Version 3.50
or 3.60 driver. The error message:
Unable to understand after -- "<string>". (247)
EXPLANATION:
If you specify two links between tables in the database, the report
works without problem but when you specify a link to a third table,
the error appears. It makes no difference if you are linking different
tables or using different linking methods.
The message means that Progress cannot understand part of the
statement. No error occurs if you use for example, MS Query.
SOLUTION
The problem does not come from either Progress or the MERANT ODBC
driver but is from within Crystal Reports Version 7.
The Seagate website has a workaround for the problem.
Follow these steps:
1) Go to the following URL:
http://support.seagatesoftware.com/updates/default.asp
2) Under the "Enter Filename Here" Label, type in
"odbcregs.zip" and press the Enter key.
This brings you to a page where you can download
the "odbcregs.zip" file.
3) Execute the "OUTJOIN.REG" file which is one of the
six files in the zipped files.
NOTE: You do not need to replace the p2sodbc.dll
file with the one included in the zipped file
because you already have the newer version.
4) Get the file name for your ODBC driver.
Go into Control Panel and open the ODBC
Administrator.
5) Click the User/System tab.
6) Find your ODBC data source.
7) Look at the driver name that corresponds with that
data source then click on the Driver Tab.
8) Look up that driver name (the file name is to
the right of that line.
For example:
Driver Name Filename
CROR7 cror713.dll
9) You must edit the Registry to add the
file name. (Always back up the Registry before
modifying it).
Go to the the following key:
HKEY_CURRENT_USER > SOFTWARE > SEAGATE
SOFTWARE > CRYSTAL REPORTS > DATABASEOPTIONS >
OUTERJOIN
Click on the PlusEqual label, right click and
choose to "modify".
Add your file name (without the .DLL).
Default value not set
AccessDriver "odbcjt16,odbcjt32,qbodbc"
DataBaseName "qeinf506,qeinf507"
10) Open Crystal Reports.
The SQL syntax should have changed to be the
correct syntax for your database.
hbackstr 23/Aug/2000
Sent: Thursday, November 08, 2001 3:31 PM
Sonya Cover
Electron Energy
Did you run the outjoin.reg file for your appropriate version of ODBC?
Troy Funte
Liberty Electronics
----- Original Message -----
Sonya Cover
Electron Energy
Here are the outjoin.reg files for you.
http://groups.yahoo.com/group/vantage/files/Reports%20-%20Crystal%20Reports/ODBC/ivpro14%20for%203.5.reg Use this one for Merant 3.5 drivers
http://groups.yahoo.com/group/vantage/files/Reports%20-%20Crystal%20Reports/ODBC/ivpro15%20for%203.6.reg Use this one for Merant 3.6 drivers
Troy Funte
Liberty Electronics
Sent: Thursday, November 08, 2001 4:19 PM
Subject: Re: [Vantage] Crystal Report Error
Troy Funte
Liberty Electronics
Sonya Cover
Electron Energy
Yahoo! Groups Sponsor
ADVERTISEMENT
At the end of last week several of you were very helpful and sent me
some information to help me correct a Crystal Report Error I was
having. The error stated: [MERANT][ODBC PROGRESS driver][PROGRESS]
**Unable to understand after--"DECLARE".(247).
I finally was able to get back to this and try to use the outjoin.reg
file and also to go in and edit the registry. I don't know if I did
something wrong of if this didn't work. I am still getting the same
message. Any suggestions? Thank you.
Sonya Cover
Electron Energy Corporation
Send me the outjoin.reg file that you used, and I'll take a look at it. Also, which version of Vantage and which ODBC driver are you using?
Troy Funte
Liberty Electronics
Sent: Friday, November 16, 2001 11:24 AM
Sonya Cover
when i run a custom report in 8.03.400 from a terminal server i receive
the following error: Method not found: "Void
CrystalDecisions.ReportAppServer.ReportDefModel.ISCRPromptingRequestInfo
.Set_RepestOptions
(CrystalDecisions.ReportAppserver.DataDefMethod.PropertyBag)"
any one seen this and have a fix.
thanks,
andrew,
I have received the same error and notified support yesterday. I have
not received a solution at this time.
Of pjnuts2
Sent: Tuesday, April 01, 2008 6:11 PM
.Set_RepestOptions
thanks,
andrew,
Attention:
This email message is privileged and confidential. If you are not the
intended recipient please delete the message and notify the sender.
Any views or opinions presented are solely those of the author.
This email message has been scanned for Viruses and Content and cleared
by MailMarshal SMTP
For more information go to http://www.ramsys.com
Is the workstation that you are running the report have Crystal Reports on
it and installed (2007) version of the run time?
Steve
Sent: April 02, 2008 9:11 AM
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
Behalf
Of pjnuts2
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
.Set_RepestOptions
thanks,
andrew,
Attention:
by MailMarshal SMTP
For more information go to http://www.ramsys <http://www.ramsys.com> com
We also saw this error when we upgraded to 8.03.404 - our ODBC reports
(using file DSN) worked fine in 8.03.305.
When we had the problem the report ran fine in Crystal but would not
run from Vista/Vantage. Once I removed the parameters then the reports
ran from Vista - just not very useful.
Our consultant called Epicor and was told it is a problem with the new
Crystal Runtime. They directed him to the Crystal/Business Objects web
site and we downloaded a new runtime version. But we were also told we
had to have the full version of Crystal loaded as well as the runtime
for the report to work properly with parameters.
I would try to preview the report in Crystal and see if it works. You
can also remove the parameters and see if it works. Give Epicor a call
to find out exactly what Crystal patch you should download.
I hope this helps.
Thanks-
Mark
receive
> .Set_RepestOptions
> thanks,
> andrew,
Mark,
Thanks, it worked. If epicor every comes up with a real solution
aside from full install of crystal reports please let me know and i
definately will do the same as i am working with Epicor to find a
better solution.
Thanks again,
Andrew,
reports
not
reports
new
web
told we
runtime
You
call
> I hope this helps.
> Thanks-
> Mark
> receive
fo
> > .Set_RepestOptions
> > thanks,
> > andrew,
I'm in the same boat.. so any solution for getting prompts to work
short of installing the full package on all clients would be useful.
Interesting too on the Business Objects site they have SP1 through
SP3 available for Crystal XI Release 2. Has anyone grabbed these and
applied them to their full Crystal package without any issues?
> Mark,
> better solution.
> Thanks again,
> Andrew,
> reports
> not
> reports
the
> new
Objects
> web
> told we
> runtime
works.
> You
a
> call
> > I hope this helps.
> > Thanks-
> > Mark
> > receive
> fo
> > > .Set_RepestOptions
> > > thanks,
> > > andrew,
In 8.03.404, I was able to convert the CR from ODBC to BAQR. I was
able to prompt and select using BAQ.
I was not able to keep any prompting in the Crystal Report itself.
This might be one option to get around the problem.
Dale
Of Patrick Parker
Sent: Thursday, April 03, 2008 9:30 AM
Subject: [Vantage] Re: Crystal Report Error
> Mark,
> better solution.
> Thanks again,
> Andrew,
> reports
> not
> reports
the
> new
Objects
> web
> told we
> runtime
works.
> You
a
> call
> > I hope this helps.
> > Thanks-
> > Mark
> > receive
> fo
> > > .Set_RepestOptions
> > > thanks,
> > > andrew,
Attention:
by MailMarshal SMTP
I had this problem on my terminal servers after installing the latest
CR runtime from the Epicor website.
I found from going through the hard drives that there were a number
of other installations of the CR runtimes - earlier, older
installations and a copy installed by a reporting program we use. I
deleted all other installations from the hard drive - not by
uninstalling, but physically deleting. The other programs weren't
affected as seem to find any required files in the latest
installation folder.
It worked. I can now run Crystal Reports with parameters without
problem.
Nigel.
> Mark,
> better solution.
> Thanks again,
> Andrew,
> reports
> not
> reports
the
> new
Objects
> web
> told we
> runtime
works.
> You
a
> call
> > I hope this helps.
> > Thanks-
> > Mark
> > receive
> fo
> > > .Set_RepestOptions
> > > thanks,
> > > andrew,
