Crystal report error after conversion
If this is using a modified report data set you probably need to start
from the base dataset. Does the base crystal work?
Also use the base crystal report as changes to joins, formulas, etc may
not be seen right away.
Of bryandavis1980
Sent: Wednesday, January 30, 2013 10:55 AM
Subject: [Vantage] Crystal report error after conversion
I am getting the following error on one of our custom reports after
upgrading from Vista 8.03.409C to Epicor 9.05.700C. Most of our reports
carried over just fine with the exception of this one so far. Has anyone
ran into this before?
Unexpected end of file has occurred. The following elements are not
closed: ReportDataSet. Line 1483, position 1.
Thank you,
Bryan
I am getting the following error on one of our custom reports after upgrading from Vista 8.03.409C to Epicor 9.05.700C. Most of our reports carried over just fine with the exception of this one so far. Has anyone ran into this before?
Unexpected end of file has occurred. The following elements are not closed: ReportDataSet. Line 1483, position 1.
Thank you,
Bryan
