Crystal Problems... again and again
I had the same problem between FAS and Vantage back in November. It was resolved by the following. FAS and Vantage CR reports now co-exist. Some of this I had posted before on another Crystal issue.
After installing FAS report writer:
1. Check
<http://support.businessobjects.com/fix/hot/si75/default.asp#Crystal%20Report> http://support.businessobjects.com/fix/hot/si75/default.asp#Crystal%20Report
s%20Service%20Packs
and scroll down to the CR 8.5 section to download Service Pack 3 (sorry if
the long link wraps badly - you might have to go to
support.businessobject.com and work down to the patches from there). Put
this on your CR development PC (assuming you have one) and then start to
compare the DLL version numbers in it and the Mfgsys61/DLL folder. Rename
the Vantage versions (DLL-Old perhaps?) and copy the newer ones from the
development PC to mfgsys61\dll folder on the Vantage server. The hot fix I think is also in the Vantage FTP files.
2. Then copy ALL the CR type .DLLs from the Vantage/DLL folder to the
System32 folder on the client PC where the report is trying to be run from.
Also copy P2BXBSE.DLL to the client's system32 folder. In particular
crpe32.dll needs to be in synch between the development PC, mfgsys61\dll
folder and the client's PC.
3. Find Sscsdk80.dll in the program Files\Seagate Software\Shared folder and
copy this to the Winnt\System32 folder (or equivalent for whichever OS) on
the client PC. There have been reports that certain forms with graphics
(like company logo) can bomb out randomly (memory issue?) without this .dll
on the client. There might also be a sscsdk32.dll too that needs to be
copied.
Most of this should overlay any "alien" .dlls from the FAS or other Crystal based report writers but not disable them. Another way I have tried for getting the lastest DLLs on the client is if you have the report distribution wizard you can "distribute" a report to the client after having checkmarked to copy DLLs (but not data files) in the wizard.
-Todd C.
Sent: Friday, January 28, 2005 10:47 AM
Subject: RE: [Vantage] Crystal Problems... again and again....
Babette,
Try printing with a client without other applications such as ABRA, Best
Software's Fixed Assets, Crystal Reports Professional or other products that
use crystal reports for reporting purposes.
I had the same problem and found by uninstalling Best Software's Fixed
Assets fixed the problem then reinstalling it recreated the issue.
My solution was to allow our 2 accounting people to run Best Software's
Fixed Asset package one at a time using XP's remote control feature to a PC
sitting in the IT department. No more mixed dlls.
Patrick Winter
Sent: Friday, January 28, 2005 10:00 AM
Subject: [Vantage] Crystal Problems... again and again....
There has been a lot of discussion about Crystal/Vantage on this forum.
I am still hoping to glean a few more words of wisdom from this group.
We have recently experienced:
AR invoices dropping detail lines
AR invoices adding unassociated Misc charges to all invoices
Mass print of Travelers not working
This was true in Vantage default reports & our modified reports.
From Tech Support we switch from Crystal 8.5.3... to 8.5.2.718 This fixed
most problems.
We still have 2 issues:
Creating new report in Crystal, 1 table (Parts). Will preview but
errors when saving "The handle is invalid".
Did verify database.
What now?
Crystal 8.5.2.718
Vantage 6.1.519
BW
_________________________________________________
Babette Welch
IT Director
Argonics, Inc
1110 Wright Street
Marquette MI 49855
906.226.9747 ext 235
906.228.0951
Yahoo! Groups Links
_____
Yahoo! Groups Links
vantage-unsubscribe@yahoogroups.com <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
This fixed most problems.
What now?
Crystal 8.5.2.718
Vantage 6.1.519
BW
Babette Welch
IT Director
Argonics, Inc
1110 Wright Street
Marquette MI 49855
906.228.0951
This is a function of poor forms creation from epicor not crystal. I have
had to change many of the forms just to get them to work and avoid problems.
I my humble opinion every company should have a crystal guru in house they
will be worth there weight in gold.
Frank Zeigafuse
Innovative Office Products
General Manager
Direct Phone: 610-559-6369
Email: fzeigafuse@...
Sent: Friday, January 28, 2005 11:00 AM
There has been a lot of discussion about Crystal/Vantage on this forum. I am
What now?
Crystal 8.5.2.718
Vantage 6.1.519
BW
Babette Welch
IT Director
Argonics, Inc
1110 Wright Street
Marquette MI 49855
906.228.0951
Yahoo! Groups Links
<www.LCDarms.com> -- Ergonomic mounting solutions for monitors and keyboards
This e-mail is from Innovative Office Products, Inc. but expresses the views of the sender and not necessarily the views of the company. The email and any files transmitted with it are confidential to the intended recipient at the e-mail address to which it has been addressed. It may not be disclosed or used by any other than that addressee, nor may it be copied in any way. If received in error, please delete and notify the sender via e-mail or sales@... quoting the name of the sender. Messages sent via this medium may be subject to delays, non-delivery and unauthorized alteration. This e-mail has been prepared using information believed by the author to be reliable and accurate. Unless expressly stated otherwise, this e-mail does not form part of a legally binding contract or agreement between recipient and Innovative Office Products, Inc.
Warning: Although Innovative Office Products, Inc. has taken reasonable precautions to ensure no viruses are present in this email, we cannot accept responsibility for any loss or damage arising from the use of this email or attachments. It is, therefore, your responsibility to scan attachments (if any).
Babette,
Patrick Winter
most problems.
What now?
Crystal 8.5.2.718
Vantage 6.1.519
BW
Babette Welch
IT Director
Argonics, Inc
1110 Wright Street
Marquette MI 49855
906.228.0951
Yahoo! Groups Links
