Crystal - ODBC
Where can I get the old Merant 3.6 (IVPRO15.dll) drivers?
Sent: Wednesday, November 28, 2001 8:54 AM
Subject: RE: [Vantage] Crystal - ODBC
I've the same problems with the Merant 3.60 32-Bit progress SQL 92 v
9.1a.
All reports base on this driver (PGPRO915.DLL) won't work properly while
printing through Vantage. The Error messages are 599 or 515.
In almost all our reports that we print through Vantage we use
sub-reports
based on ODBC to extract additional information that's not available in
the
dbf files. Using the "old" Merant 3.6 drivers (IVPRO15.DLL) works fine.
Epicor advises to use the IVPRO15.DLL driver.
Erik Weiffenbach
Sent: woensdag 21 november 2001 13:30
Subject: Re: [Vantage] Crystal - ODBC
Ryan,
I just got a brainstorm this morning (hope it's not snow). Did you
use
the Merant 3.5 in 4.0 and now are using the SQL-92 drivers for 5.0? We
were
using Merant 3.5 for 5.0 (which is the version we are on now LIVE, and
our
ODBC link to the POFORM.rpt works fine). Now in testing 5.1 with the
SQL-92
drivers, this ODBC link gets the Error 599. I'm thinking it has to do
with
the ODBC login/password that SQL-92 uses. If you notice, when
previewing
your report in Vantage it never asks you to login to ODBC. This is not a
problem with Merant 3.5 because there is no username or password. Now
in
SQL-92, you must supply a username and password.
This is just a theory, and when I get a chance, I may test this with
Merant
3.5. The main hassle of this is that I'll have to shut down Progress
Explorer and go back to ProControl. I'll let you know if I find
anything
out, and you please do the same.
Troy Funte
Liberty Electronics
----- Original Message -----
Sent: Tuesday, November 20, 2001 2:59 PM
Troy,
I will let you know if I figure out a better solution. I can't
believe
you and I are the only ones having this problem. It is really
frustrating to have spent many hours on our quote form and sales order
form and for them not to work with Vantage 5.0. I wish Epicor would
respond and try to get this resolved instead of emailing me what they
think is a fix. What I don't understand is all these forms worked
great
in Vantage 4.0.
Ryan Larkin
Vice President
Solid Comfort, Inc./Solid Performance
Fargo, ND 58104
701-282-4900
Sent: Tuesday, November 20, 2001 10:50 AM
Ryan,
I've been battling this same issue (Error 599) when trying to add
an
ODBC table to the POFORM.rpt report in Vantage. It works fine in 5.0,
but just as soon as I put the subreport in the report with the
ODBC.PORel table, then I get the Error 599. I've done all that you've
described as well.
I did find a workaround solution. Because we do nightly Exports
from
Vantage for other reports this option may work for us. Here's what I
found...
1. Export the POREL table with the necessary fields to a DBF file.
2. Create an Access Table that is directly Linked to the Exported DBF
table.
3. Create a Query on the above Access Table.
4. Create a System DNS for Access which points to this Access
Database.
5. The Access DNS seems to work fine in the Subreport and gives me the
necessary fields to pass in a Shared Variable to the main report. (I
just need the "ReceivedQty" from that table).
Once the above is set up, only the Export (Step 1) needs to be done
nightly.
Let me know if you have any questions. Also, PLEASE let me know if
you
find a better solution. I don't like this rinky-dink solution at all.
Troy Funte
Liberty Electronics
Sent: Monday, November 19, 2001 12:30 PM
Subject: [Vantage] Crystal - ODBC
I am currently running Vantage 5.00.331 and updating my Crystal
Reports
using Crystal 8.0. I am running the Merant 3.6 SQL 92 driver to
update
my reports. I am receiving the infamous Error 599. I have called
Epicor many times on this issue but I have got no where. I started
my
reports over from scratch and I am still getting the error. I have
run
the unregocx and the vcopydll per Epicor but still haven't had ANY
luck
whatsoever. Is there anyone that has had this problem and solved
it?
If so, I would appreciate any help possible.
Ryan Larkin
Vice President
Fargo, ND 58104
701-282-4900
Useful links for the Yahoo!Groups Vantage Board are: ( Note: You
must
have already linked your email address to a yahoo id to enable access.
(1) To access the Files Section of our Yahoo!Group for Report
Builder
http://docs.yahoo.com/info/terms/
Yahoo! Groups Sponsor
and
have
and
I am currently running Vantage 5.00.331 and updating my Crystal Reports
using Crystal 8.0. I am running the Merant 3.6 SQL 92 driver to update
Epicor many times on this issue but I have got no where. I started my
reports over from scratch and I am still getting the error. I have run
the unregocx and the vcopydll per Epicor but still haven't had ANY luck
whatsoever. Is there anyone that has had this problem and solved it?
Ryan Larkin
Vice President
Fargo, ND 58104
701-282-4900
Ryan,
I've been battling this same issue (Error 599) when trying to add an ODBC table to the POFORM.rpt report in Vantage. It works fine in 5.0, but just as soon as I put the subreport in the report with the ODBC.PORel table, then I get the Error 599. I've done all that you've described as well.
I did find a workaround solution. Because we do nightly Exports from Vantage for other reports this option may work for us. Here's what I found...
2. Create an Access Table that is directly Linked to the Exported DBF table.
4. Create a System DNS for Access which points to this Access Database.
5. The Access DNS seems to work fine in the Subreport and gives me the necessary fields to pass in a Shared Variable to the main report. (I just need the "ReceivedQty" from that table).
Once the above is set up, only the Export (Step 1) needs to be done nightly.
Let me know if you have any questions. Also, PLEASE let me know if you find a better solution. I don't like this rinky-dink solution at all.
Troy Funte
Liberty Electronics
Ryan Larkin
Vice President
Fargo, ND 58104
701-282-4900
Troy,
I will let you know if I figure out a better solution. I can't believe
think is a fix. What I don't understand is all these forms worked great
in Vantage 4.0.
Ryan Larkin
Vice President
Fargo, ND 58104
701-282-4900
Ryan,
described as well.
found...
table.
nightly.
Troy Funte
Liberty Electronics
Reports
update
run
luck
Ryan Larkin
Vice President
Fargo, ND 58104
701-282-4900
Ryan,
I just got a brainstorm this morning (hope it's not snow). Did you use the Merant 3.5 in 4.0 and now are using the SQL-92 drivers for 5.0? We were using Merant 3.5 for 5.0 (which is the version we are on now LIVE, and our ODBC link to the POFORM.rpt works fine). Now in testing 5.1 with the SQL-92 drivers, this ODBC link gets the Error 599. I'm thinking it has to do with the ODBC login/password that SQL-92 uses. If you notice, when previewing your report in Vantage it never asks you to login to ODBC. This is not a problem with Merant 3.5 because there is no username or password. Now in SQL-92, you must supply a username and password.
This is just a theory, and when I get a chance, I may test this with Merant 3.5. The main hassle of this is that I'll have to shut down Progress Explorer and go back to ProControl. I'll let you know if I find anything out, and you please do the same.
Troy Funte
Liberty Electronics
Troy,
in Vantage 4.0.
Ryan Larkin
Vice President
Fargo, ND 58104
701-282-4900
Ryan,
described as well.
found...
table.
nightly.
Troy Funte
Liberty Electronics
Reports
update
run
luck
Ryan Larkin
Vice President
Fargo, ND 58104
701-282-4900
Ryan,
I just did some testing, and sure enough - the Error 599 disappears with the Merant 3.5 drivers installed. I have contacted Epicor about this as the problem seems to be with the SQL-92's Login procedure, and the fact that it needs a username and password to proceed. (The Merant driver needs neither). In Vantage the Crystal report doesn't get a chance to verify the login, and thus it gives the Error 599.
When I get a call number on this, I'll send it to you so you can join me in requesting that Epicor look into this "weakness" of the SQL-92 driver.
Here are two articles on the issue. The first seems most relevent to our situation.
http://support.crystaldecisions.com/library/kbase/articles/C2001630.asp
http://support.crystaldecisions.com/library/kbase/articles/C2002982.asp
Troy Funte
Liberty Electronics
Sent: Wednesday, November 21, 2001 7:29 AM
Ryan,
Troy Funte
Liberty Electronics
Troy,
in Vantage 4.0.
Ryan Larkin
Vice President
Fargo, ND 58104
701-282-4900
Ryan,
described as well.
found...
table.
nightly.
Troy Funte
Liberty Electronics
Reports
update
run
luck
Ryan Larkin
Vice President
Fargo, ND 58104
701-282-4900
Troy & Ryan,
Sorry I didn't recognize your problem early enough to be of
assistance, but I did have problems using the new ODBC driver with
5.0 on customized forms. I am using the 3.6 driver to avoid the
login problem. At the time, I complained about the change in the
driver mandating a login, but support said it was necessary and not
going away. While the added security is nice, most users would call
it a nuisance for normal reports, and it just plain doesn't work with
customized forms. It would be nice if they could require a login for
working with a linked table, but not for simply running a report,
form or query off of the linked table. I would like to add my name
to the call also.
Brian Stenglein
Clow Stamping Company
--- In vantage@y..., "Troy Funte" <tfunte@e...> wrote:
> Ryan,
the Error 599.
SQL-92 driver.
to our situation.
p
p
> Troy Funte
> Liberty Electronics
> From: Troy Funte
> To: vantage@y...
> Ryan,
> Troy Funte
> Liberty Electronics
> From: Ryan Larkin
> To: vantage@y...
> Troy,
believe
sales order
would
what they
worked great
> in Vantage 4.0.
> Ryan Larkin
> Vice President
> Fargo, ND 58104
> 701-282-4900
> From: Troy Funte [mailto:tfunte@e...]
> To: vantage@y...
> Ryan,
to add an
in 5.0,
you've
> described as well.
Exports from
what I
> found...
file.
Exported DBF
> table.
Database.
me the
report. (I
done
> nightly.
know if you
at all.
> Troy Funte
> Liberty Electronics
> From: Ryan Larkin
> To: vantage@y...
Crystal
> Reports
to
> update
called
started my
I have
> run
had ANY
> luck
solved it?
> Ryan Larkin
> Vice President
> Fargo, ND 58104
> 701-282-4900
You must
access. )
Builder
goto:
Service.
You must
access. )
Builder
enable access. )
Service.
access. )
Service.
I've the same problems with the Merant 3.60 32-Bit progress SQL 92 v 9.1a.
In almost all our reports that we print through Vantage we use sub-reports
based on ODBC to extract additional information that's not available in the
Erik Weiffenbach
Ryan,
Troy Funte
Liberty Electronics
Troy,
in Vantage 4.0.
Ryan Larkin
Vice President
Fargo, ND 58104
701-282-4900
Ryan,
described as well.
found...
table.
nightly.
Troy Funte
Liberty Electronics
Reports
update
run
luck
Ryan Larkin
Vice President
Fargo, ND 58104
701-282-4900
