Crystal/ODBC 'Left Outer Join' Error [bayes]
Actually there is a registry fix that you must run to fix this
problem. I think tech support will have the information on it for
you.
Brian Stenglein
Clow Stamping Co.
--- In vantage@yahoogroups.com, "Kathy Schmidt" <kathyschmidt@f...>
wrote:
> First delete all the ODBC links provided by Progress.
> Second, create new links on only those indexes that you know are
unique
> to each field. I don't use the "equal" join very often, but I do
use
> the "left outer join" all the time.
> Try this first.
> John
> I finally got our ODBC to connect.
> However, it will only let me create 'Left Outer Join' links in
> Crystal. If I try to create an 'Equal join', I get the following
> errors:
> "ODBC error: [DataDirect-Technologies][ODBC Progress Driver] The
> keywords LEFT OUTER JOIN were not found in an outer join escape
> sequence"
> "Error detected by database DLL"
> What am I missing?
> Scott Zwieg
> IS Manager
> IMS-Electrol
> (262) 966-3741 Ext. 230
> Fax: (262) 966-7021
> szwieg@i...
must
> have already linked your email address to a yahoo id to enable
access. )
Builder
> and Crystal Reports and other 'goodies', please goto:
> Yahoo! Groups Links
Second, create new links on only those indexes that you know are unique
to each field. I don't use the "equal" join very often, but I do use
Try this first.
John
errors:
sequence"
What am I missing?
Scott Zwieg
IS Manager
IMS-Electrol
Fax: (262) 966-7021
szwieg@...
Yahoo! Groups Links
