Crystal - Error 599
Lois,
Below is the email from Dan Shallbetter about the File DSN. I was never able to get it to work myself (about 1 1/2 years ago, but haven't tried it since). Dan also sent the following links to shed some light on the subject:
Dan wrote:
Yes I created a files DSN. Again I can't recall exactly what I did. But I
think these 2 links will shed some light on it.
http://support.crystaldecisions.com/library/kbase/articles/c2002982.asp
<http://support.crystaldecisions.com/library/kbase/articles/c2002982.asp>
http://eportal.epicor.com/eportal/ansbook/vantage/public/1/17/173/1732mps.ht
m
<http://eportal.epicor.com/eportal/ansbook/vantage/public/1/17/173/1732mps.h
tm>
Troy Funte
Liberty Electronics
Date: Thu Sep 26, 2002 3:32 pm
Subject: RE: [Vantage] Crystal - Error 599
Hello Babette
I added the the part & part rev table through a subreport to the standard
Crystal traveler report in Vantage 5.0 0. I am using Crystal 8.0 and the
SQL 92 driver that shipped with Vantage. It's been awhile since I created
this report and a lot of it was cry and error. I think what I did was
created a file DSN to use with the ODBC subreport. I also searched the KB
of Progress & Crystal for additional insight. Let me know if I can be of any
further assistance.
Dan Shallbetter
----- Original Message -----
To: 'vantage@yahoogroups.com'
Sent: Tuesday, October 01, 2002 8:58 AM
Subject: RE: [Vantage] Re: Crystal - Error 599
I missed Dan's thread on file DNS. Can you send it again?
Sent: Tuesday, October 01, 2002 12:26 PM
Subject: Re: [Vantage] Re: Crystal - Error 599
Lois,
Thanks for the info. Did you try the File DNS that Dan suggested? Like
I've said before, I have never gotten this process to work using the
Progress ODBC drivers that you are using. We use aftermarket Merant drivers
(3.5) and it works that way. Perhaps Dan can provide some more help for
you. I've never received a prowin32 error in your current situation, so I'm
not sure what next.
Perhaps as one more try... install Crystal but don't unistall it... Then
test to see if the report works while Crystal is installed. If it does,
then I have heard of others just deleting the .exe file for crystal instead
of fully uninstalling it.
Troy
Sent: Tuesday, October 01, 2002 6:59 AM
this is win98 wkstation. It is working with Vantage off a W2k server. I
installed crystal and then uninstalled it. When I open the pack list in
Vantage and choose to print preview up comes the prowin32 error. I can
print/preview the pack list in crystal just fine. THis is ODBC Merant
3.60
32 bit Progress SQL92 v.9.1D. Vantage is 5.00.350.
Sent: Tuesday, October 01, 2002 11:50 AM
Lois,
Can you give a bit more detail? Did you install Crystal? What OS are
you
working on. At what point do you get a prowin32 error (ie. when you log
in,
when you run the report, etc). Can you print/preview the report in
Crystal
designer? Which ODBC driver are you using? Which version of Vantage?
Troy Funte
Liberty Electronics
Sent: Tuesday, October 01, 2002 6:45 AM
Did this now I get a prowin32 error... "Prowin caused an invalid page
fualt
in module crpe32.dll. What now?
Sent: Tuesday, October 01, 2002 11:21 AM
Lois,
On the workstations that use our modified POForm.rpt report (which
has
added ODBC fields) I also have to install Crystal 8.0 on each
workstation,
and then undelete it (which leaves the .dll files from Crystal on the
workstation). On XP workstations, I have to do an extra step because XP
removes all the .dll files when I uninstall. On XP workstations I
install
Crystal, then copy the whole "System32 folder" to a temporary location,
then
uninstall Crystal, then copy the whole temp folder back to the System32
folder -- answering NO to overwrite any files. This leaves only the NEW
.dll's being copied back to the System32 folder.
That should clear up your crpe32.dll error.
Troy Funte
Liberty Electronics
Sent: Tuesday, October 01, 2002 5:34 AM
Subject: [Vantage] Re: Crystal - Error 599
You do need to copy the crpe32.dll to your windows/system directory
along with the p2sodbc.dll.
HTH,
Brian Stenglein
Clow Stamping Company
--- In vantage@y..., "Heisey, Lois" <lheisey@m...> wrote:
> So how does one resolve the issue? My error says "could not load
DLL
> procedure crpe32.dll(3258). What does it mean and is there any
means to
> correct it?
> From: Ted Kitch [mailto:ted@m...]
> Sent: Monday, September 30, 2002 2:59 PM
> To: 'vantage@y...'
> These errors can also be caused due to DLL issues with Crystal. 599
> basically boils down to the ODBC driver not being able to logon to
the
> server.
> Ted Kitch
> ted@m...
> From: Babette Welch [mailto:bwelch@a...]
> Sent: Monday, September 30, 2002 7:52 AM
> To: vantage@y...
> Hello to Troy & Dan & others:
> Currently using 3.60 Merant ODBC
> Will try the
> creation of a file DNS instead of a system DNS, etc.
> It is frustrating since I had these and numerous other modified and
compiled
> reports working in
> Vantage 4.0 now I have to spend time fixing these in this enhanced
Vantage
> 5.1
> Will I continue to have problems when we change to Vantage 5.2?
> Thanks for all assistance.
> BW
> Babette Welch
> MIS Director
> Argonics
> 1110 Wright
> Marquette MI 49855
> 906.226.9747 ext 235
> 906.228.0951 fax
must have
Builder and
> <http://groups.yahoo.com/group/vantage/files/>
> <http://groups.yahoo.com/group/vantage/messages>
> <http://groups.yahoo.com/group/vantage/links>
> Your use of Yahoo! Groups is subject to the Yahoo!
> <http://docs.yahoo.com/info/terms/> Terms of Service.
must have
Builder and
Yahoo! Groups Sponsor
ADVERTISEMENT
and
have
and
ADVERTISEMENT
and
have
The knowledge in this group is wonderful. I hope I can get help with this.
Have modified the Crystal versions of
Sales Order & the Traveler
Have added an new table to each.
Sales Order
OrdDtl. partnum --> part.partnum
Traveler
JobMtrl.partnum --> partBin.partnum
Have verified the database in Crystal.
When running through Vantage get an
'Error 599'
Any suggestions?
Contact me off line if the answer is too involved.
Thank you
Babette Welch
MIS Director
Argonics
1110 Wright
Marquette MI 49855
906.228.0951 fax
What ODBC Version are you using?
Brian Stenglein
Clow Stamping Co.
with this.
> Sales Order
> Traveler
> 'Error 599'
> Any suggestions?
> Thank you
> Babette Welch
> MIS Director
> Argonics
> 1110 Wright
> Marquette MI 49855
> 906.228.0951 fax
Babette,
Adding an ODBC table to a Vantage form will NOT work for the SQL-92 drivers for Progress 9.1C or earlier. I just heard through Epicor that the issue is fixed in the Progress 9.1D version of SQL-92 ODBC, which is available for Vantage 5.2.
However, if you have access to the Merant ODBC drivers (aftermarket) you should be able to do what you are attempting. We use a modified POForm.rpt that has an extra ODBC table in it.
Troy Funte
Liberty Electronics
Sent: Thursday, September 26, 2002 1:55 PM
Subject: [Vantage] Crystal - Error 599
Sales Order
Traveler
'Error 599'
Any suggestions?
Thank you
Babette Welch
MIS Director
Argonics
1110 Wright
Marquette MI 49855
906.228.0951 fax
ADVERTISEMENT
Hello Babette
further assistance.
Dan Shallbetter
Sent: Thursday, September 26, 2002 1:23 PM
Subject: Re: [Vantage] Crystal - Error 599
Babette,
Troy Funte
Liberty Electronics
Sales Order
Traveler
'Error 599'
Any suggestions?
Thank you
Babette Welch
MIS Director
Argonics
1110 Wright
Marquette MI 49855
906.228.0951 fax
ADVERTISEMENT
ADVERTISEMENT
<http://rd.yahoo.com/M=221745.2287884.3710693.2225243/D=egroupweb/S=17050071
83:HM/A=1207826/R=0/*http://www.buywirelessnow.com/sonyericsson/handset_T68i
.asp>
<http://us.adserver.yahoo.com/l?M=221745.2287884.3710693.2225243/D=egroupmai
l/S=:HM/A=1207826/rand=764927366>
Wow Dan. I didn't realize you found a way around that problem. So you created a File DNS instead of a System DNS? And that worked? Do you remember what else you had to do?
Troy Funte
Liberty Electronics
Sent: Thursday, September 26, 2002 3:32 PM
Hello Babette
further assistance.
Dan Shallbetter
Babette,
Troy Funte
Liberty Electronics
Sales Order
Traveler
'Error 599'
Any suggestions?
Thank you
Babette Welch
MIS Director
Argonics
1110 Wright
Marquette MI 49855
906.228.0951 fax
ADVERTISEMENT
ADVERTISEMENT
.asp>
ADVERTISEMENT
Troy.
m
tm>
The Joys of getting old, can't remember much past yesterday.
Dan Shallbetter
States Electric Mfg.
Sent: Thursday, September 26, 2002 3:51 PM
Troy Funte
Liberty Electronics
Hello Babette
any
further assistance.
Dan Shallbetter
Babette,
the
POForm.rpt
Troy Funte
Liberty Electronics
this.
Sales Order
Traveler
'Error 599'
Any suggestions?
Thank you
Babette Welch
MIS Director
Argonics
1110 Wright
Marquette MI 49855
906.228.0951 fax
Just a FYI. The latest 5.20.211 patch has the following to say about this issue:...
CY Crystal Reports SCR 4498 5.20.210
To successfully print a customized Crystal report that contains a sub report and uses an ODBC connection, the following parameters need to be defined in the vtg file for Vantage:
VantageODBCServer=xxxxxxx (name of odbc server or connection)
VantageODBCDbse=xxxxxxx(database name)
VantageODBCUser=xxxxxxx(database logon userid)
VantageODBCpasswd=xxxxxxxxx(database logon password)
Previously, running the report would result in a 599 error.
Troy Funte
Liberty Electronics
Sent: Thursday, September 26, 2002 5:07 PM
Troy.
m
tm>
Dan Shallbetter
Troy Funte
Liberty Electronics
Hello Babette
any
further assistance.
Dan Shallbetter
Babette,
the
POForm.rpt
Troy Funte
Liberty Electronics
this.
Sales Order
Traveler
'Error 599'
Any suggestions?
Thank you
Babette Welch
MIS Director
Argonics
1110 Wright
Marquette MI 49855
906.228.0951 fax
ADVERTISEMENT
Actually, this info. was already in the .210 patch, but here are the instructions to make it work anyway.
Troy
Sent: Thursday, September 26, 2002 6:37 PM
Troy Funte
Liberty Electronics
Troy.
m
tm>
Dan Shallbetter
Troy Funte
Liberty Electronics
Hello Babette
any
further assistance.
Dan Shallbetter
Babette,
the
POForm.rpt
Troy Funte
Liberty Electronics
this.
Sales Order
Traveler
'Error 599'
Any suggestions?
Thank you
Babette Welch
MIS Director
Argonics
1110 Wright
Marquette MI 49855
906.228.0951 fax
ADVERTISEMENT
ADVERTISEMENT
Will try the
It is frustrating since I had these and numerous other modified and compiled reports working in
Vantage 4.0 now I have to spend time fixing these in this enhanced Vantage 5.1
BW
Babette Welch
MIS Director
Argonics
1110 Wright
Marquette MI 49855
906.228.0951 fax
basically boils down to the ODBC driver not being able to logon to the
server.
Ted Kitch
ted@...
Will try the
reports working in
5.1
BW
Babette Welch
MIS Director
Argonics
1110 Wright
Marquette MI 49855
906.228.0951 fax
So how does one resolve the issue? My error says "could not load DLL
procedure crpe32.dll(3258). What does it mean and is there any means to
correct it?
server.
Ted Kitch
ted@...
Will try the
reports working in
5.1
BW
Babette Welch
MIS Director
Argonics
1110 Wright
Marquette MI 49855
906.228.0951 fax
Babette,
Supposedly that issue has been resolved in 9.1D of Progress (aka Vantage
5.2). I don't know of anyone who has tried it yet - I haven't had the time.
There is a set of lines that you add to the vantage.vtg file as follows:
That's about all I know for now. Virginia at Epicor was the person looking
into this issue previously and may know the most about it.
Troy Funte
Liberty Electronics
Sent: Monday, September 30, 2002 8:51 AM
Will try the
5.1
BW
Babette Welch
MIS Director
Argonics
1110 Wright
Marquette MI 49855
906.228.0951 fax
I installed 9.1D and added these parameters to the vtg and still 599 occurs.
any other ideas?
Sent: Monday, September 30, 2002 3:51 PM
To: Vantage
Babette,
Troy Funte
Liberty Electronics
Will try the
5.1
BW
Babette Welch
MIS Director
Argonics
1110 Wright
Marquette MI 49855
906.228.0951 fax
HTH,
Brian Stenglein
DLL
means to
> correct it?
> To: 'vantage@y...'
the
> server.
> Ted Kitch
> ted@m...
> To: vantage@y...
> Will try the
compiled
> reports working in
Vantage
> 5.1
> BW
> Babette Welch
> MIS Director
> Argonics
> 1110 Wright
> Marquette MI 49855
> 906.228.0951 fax
must have
Builder and
must have
Builder and
Lois,
On the workstations that use our modified POForm.rpt report (which has added ODBC fields) I also have to install Crystal 8.0 on each workstation, and then undelete it (which leaves the .dll files from Crystal on the workstation). On XP workstations, I have to do an extra step because XP removes all the .dll files when I uninstall. On XP workstations I install Crystal, then copy the whole "System32 folder" to a temporary location, then uninstall Crystal, then copy the whole temp folder back to the System32 folder -- answering NO to overwrite any files. This leaves only the NEW .dll's being copied back to the System32 folder.
Troy Funte
Liberty Electronics
HTH,
Brian Stenglein
DLL
means to
> correct it?
> To: 'vantage@y...'
the
> server.
> Ted Kitch
> ted@m...
> To: vantage@y...
> Will try the
compiled
> reports working in
Vantage
> 5.1
> BW
> Babette Welch
> MIS Director
> Argonics
> 1110 Wright
> Marquette MI 49855
> 906.228.0951 fax
must have
Builder and
must have
Builder and
ADVERTISEMENT
Did this now I get a prowin32 error... "Prowin caused an invalid page fualt
Lois,
Troy Funte
Liberty Electronics
HTH,
Brian Stenglein
DLL
means to
> correct it?
> To: 'vantage@y...'
the
> server.
> Ted Kitch
> ted@m...
> To: vantage@y...
> Will try the
compiled
> reports working in
Vantage
> 5.1
> BW
> Babette Welch
> MIS Director
> Argonics
> 1110 Wright
> Marquette MI 49855
> 906.228.0951 fax
must have
Builder and
must have
Builder and
ADVERTISEMENT
Lois,
Can you give a bit more detail? Did you install Crystal? What OS are you working on. At what point do you get a prowin32 error (ie. when you log in, when you run the report, etc). Can you print/preview the report in Crystal designer? Which ODBC driver are you using? Which version of Vantage?
Troy Funte
Liberty Electronics
Lois,
Troy Funte
Liberty Electronics
HTH,
Brian Stenglein
DLL
means to
> correct it?
> To: 'vantage@y...'
the
> server.
> Ted Kitch
> ted@m...
> To: vantage@y...
> Will try the
compiled
> reports working in
Vantage
> 5.1
> BW
> Babette Welch
> MIS Director
> Argonics
> 1110 Wright
> Marquette MI 49855
> 906.228.0951 fax
must have
Builder and
must have
Builder and
ADVERTISEMENT
ADVERTISEMENT
print/preview the pack list in crystal just fine. THis is ODBC Merant 3.60
Lois,
Troy Funte
Liberty Electronics
fualt
Lois,
then
Troy Funte
Liberty Electronics
HTH,
Brian Stenglein
DLL
means to
> correct it?
> To: 'vantage@y...'
the
> server.
> Ted Kitch
> ted@m...
> To: vantage@y...
> Will try the
compiled
> reports working in
Vantage
> 5.1
> BW
> Babette Welch
> MIS Director
> Argonics
> 1110 Wright
> Marquette MI 49855
> 906.228.0951 fax
must have
Builder and
must have
Builder and
ADVERTISEMENT
and
have
ADVERTISEMENT
Lois,
Thanks for the info. Did you try the File DNS that Dan suggested? Like I've said before, I have never gotten this process to work using the Progress ODBC drivers that you are using. We use aftermarket Merant drivers (3.5) and it works that way. Perhaps Dan can provide some more help for you. I've never received a prowin32 error in your current situation, so I'm not sure what next.
Perhaps as one more try... install Crystal but don't unistall it... Then test to see if the report works while Crystal is installed. If it does, then I have heard of others just deleting the .exe file for crystal instead of fully uninstalling it.
Troy
Lois,
Troy Funte
Liberty Electronics
fualt
Lois,
then
Troy Funte
Liberty Electronics
HTH,
Brian Stenglein
DLL
means to
> correct it?
> To: 'vantage@y...'
the
> server.
> Ted Kitch
> ted@m...
> To: vantage@y...
> Will try the
compiled
> reports working in
Vantage
> 5.1
> BW
> Babette Welch
> MIS Director
> Argonics
> 1110 Wright
> Marquette MI 49855
> 906.228.0951 fax
must have
Builder and
must have
Builder and
ADVERTISEMENT
and
have
ADVERTISEMENT
