I have tried CTE and temporary table to create a cross join which works outside Epicor but not in Epicor.
What am I doing wrong or what should I do?
I have various versions as I tested with substituting test values for database values.
Note: the versions with table guid do return just a single row instead of 30 or relevant number of rows created by the union.
V1.
="WITH RowsQty AS (
SELECT 1 AS RowsX4
UNION ALL
SELECT 1 + RowsX4
FROM RowsQty
WHERE RowsX4 < 30
SELECT * from (SELECT T1.JobNum,T2.PartNum
FROM JobHead_" + Parameters!TableGuid.Value + " T1
LEFT OUTER JOIN JobAsmbl_" + Parameters!TableGuid.Value + " T2
ON T1.Company = T2.Company AND T1.JobNum = T2.JobNum) st1
CROSS JOIN RowsQty"
V2.
="WITH RowsQty AS (
SELECT 1 AS RowsX4
UNION ALL
SELECT 1 + RowsX4
FROM RowsQty
WHERE RowsX4 < (SELECT ProdQty / 4 + case when ProdQty % 4 > 0 then 1 else 0 end FROM JobHead_" + Parameters!TableGuid.Value + " T1 where t1.JobNum = '" +Parameters!SR_JobNum.Value.ToString() +"')
CROSS JOIN RowsQty"
V3.
DECLARE @i int = 0
create table RowsQty (RowsX4 int)
WHILE @i < 20
BEGIN
SET @i = @i + 1
insert into RowsQty (RowsX4) values (@i)
END;
Select * from (SELECT 'FRM000123' as JobNum, 'KLM010203' as PartNum) t1
CROSS JOIN RowsQty
Test link for arbitrary data outside Epicor.
