Since the settings in Company Configuration are tied together, Credit/Aging, I’m struggling to separate the rules that finance wants to follow. They do not want a job to be created when the customer is on aging hold.
Customer Credit Hold = Warn
Customer Aging Hold = Stop
If an order will be be allowed to be entered then you have a couple options.
Set the OrderRelease to UnFirm. This will prevent the OrderRelease from creating a unfirm job from MRP and also the Order will not show up on the planning workbench.
Leave the Shipto blank - this will prevent the OrderJobWizard from working.
A Datadirective may be required depending on how you are creating Orders.
Hi
The best way of stopping production is (as previously mentioned) by setting the Order Release to Un-firm. There are a number of ways in which orders can be created and manipulated.
I have attached a .cab file that contains BPMs that will:
Set the unfirm release flag on a sales order release created from a quote
Set the unfirm release flag on a sales order release created manually
