I want a ‘Crystal Reports’ report to print when a specific Operation is complete. I know that I can print this report as a traveler, it works fine but I’m trying to have it print out once triggered. Is this even possible in Epicor 9.5? I think it is I just need to code it in a BPM. I already have a BPM that sends an email with the same trigger and information I just don’t know what ABL code to use to send a report to a printer. Help
You will have to design a report style and use a BAM to auto print it based on the trigger you need.
Vinay Kamboj
I created a report style ReelLabel and linked the report. I then went and created a BAM for table JobHead:
- does not list the 1 field I need, LineDesc
- under action I check Auto-print and enter the ReportID I created and the Data Definition… I keep getting an ‘The ReportID is not valid.’ error.
Exception caught in: Epicor.Mfg.BO.ChgLogGA
Error Detail
Message: The ReportID is not valid.
Type: Error
Program: bo/ChgLogGA/ChgLogGA.p
Method: chgLogGABeforeUpdate
Table: ChgLogGA
Row:
Field:
Stack Trace
at Epicor.Mfg.Proxy.ChgLogGAImpl.Update(ChgLogGADataSet ds)
at Epicor.Mfg.UI.Adapters.ChgLogGAAdapter.Update()
at Epicor.Mfg.UI.App.ChgLogGAEntry.Transaction.Update()
Inner Exception
ERROR condition: The Server application has returned an error. (7243) (7211)
Inner Stack Trace
at Progress.Open4GL.DynamicAPI.Session.runProcedure(String requestID, String procedureName, ParameterSet parms, Boolean persistent, Boolean internal_Renamed, Int64 procId, MetaSchema localSchema, Int32 stateModel)
at Progress.Open4GL.DynamicAPI.Session.runStatelessProcedure(String requestID, String fullProcedureName, ParameterSet inparams, Object procId, MetaSchema localSchema, Int32 stateModel)
at Progress.Open4GL.DynamicAPI.PersistentProc.runTheProcedure(String requestID, String procedureName, ParameterSet parms, MetaSchema schema)
at Progress.Open4GL.DynamicAPI.PersistentProc.runProcedure(String procedureName, ParameterSet parms, MetaSchema schema)
at Epicor.Mfg.Core.CallContext.CallContextPersistentProc.runProcedure(String procedureName, ParameterSet parameters, MetaSchema metaSchema)
at Epicor.Mfg.Core.CallContext.ProxyHelper.CallMethod(String methodName, ParameterSet parameters, MetaSchema metaSchema, BLConnectionPool connPool, Session connection, PersistentProc persistProc, CallContextDataSet callContextDataSet)
Probably RDD does not have the table JobHead in it.
Vinay Kamboj
Found it, it was there but I must be blind.
My other issue is I need 1 field from another table. I can actually code all this in BPM, I can create the condition and pull all the fields I need. I do the exact same thing for an email. I just don’t know how to make the report print
And the RDD does have JobHead and all required tables/fields because it is a custom RDD I created for all Travelers and use it to test this current report. I’m not sure why it’s stating that the ReportID is not valid.
BUT I have also realized that my condition is not simple enough for a BAM. The trigger is in JobEntry but not JobHead, the trigger is the completion of a specific Operation. I need 1 field from JobHead and 1 field from SerialNo to populate the report.
Maybe I need to look outside of Job Entry for the trigger
