Yes. :)
There is, in my opinion, a bug in the CustCntAdapter.
When trying to use a QuickSearch on its search window, it does not
return the row(s) that were selected.
I'm trying to recreate the searching process to try and work around this
"bug".
It would be pretty tough to figure this out in Epicor's customization
tool due to the lack of functionality of the IDE.
I'm trying to do the work in VS2010 and then copy the code into a
customization.
Before I can even start testing, I'm trying to setup my VS Project to
simply connect to the appserver and then display the CustCntAdapter
search window, which is where I'm stuck.
vantage@yahoogroups.com [mailto:
vantage@yahoogroups.com] On Behalf
Of Sean McDaniel
Sent: Wednesday, September 22, 2010 3:12 PM
To:
vantage@yahoogroups.com;
Subject: RE: [Vantage] Creating a Visual Studio Project to connect to
Epicor/Vantage
Is there a reason that you're going this route instead of just using the
web services?
Joe Rojas | Director of Information Technology | Mats Inc
dir: 781-573-0291 | cell: 781-408-9278 | fax: 781-232-5191
jrojas@... | www.matsinc.com Ask us about our clean, green and beautiful matting and flooring
This message is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake. Please note that any views or opinions presented in this email are solely those of the author and do not necessarily represent those of the company.
vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> on
behalf of Joe Rojas
Sent: Wed 9/22/2010 2:41 PM
To:
Epicor/Vantage
Thanks Mark,
Copying the config folder to the debug folder of my project worked.
Thanks!
Now I'm having a problem initializing the adapter. It seems that the BO
is not connecting.
When I look at some examples I've created within Epicor, I've been using
oTrans instead of a Session object in the line that reads:
CustCntAdapter adpCustCnt = new
CustCntAdapter(epiSession.ConnectionPool);
As I walk through the code, it looks like the when the CustCntAdapter is
being instantiated, it is trying to cast the ConnectionPool to an
IEpiTransaction, which it cannot.
Does this mean I need to create an oTrans for my project? If I do,
normally oTrans is based off of the Transaction member of an Epicor
screen, like Project Entry or Order Entry. Is there a way to make a
generic Transaction object?
Thanks for your help so far Mark!
<mailto:vantage%40yahoogroups.com> [mailto:
<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ]
On Behalf
Of Mark Wonsil
Sent: Wednesday, September 22, 2010 2:16 PM
To:
Subject: Re: [Vantage] Creating a Visual Studio Project to connect to
Epicor/Vantage
Joe Wrote:
> Right now, I just have a form with one button that has my code in the
> Click event.
> using System;
> using System.Collections.Generic;
> using System.ComponentModel;
> using System.Data;
> using System.Drawing;
> using System.Linq;
> using System.Text;
> using System.Windows.Forms;
> using Epicor.Mfg.Core;
> using Epicor.Mfg.UI;
> using Epicor.Mfg.UI.Adapters;
> using Epicor.Mfg.UI.Searches;
> namespace EpicorSearchCSharpTake2
> public partial class Form1 : Form
> public Form1()
> InitializeComponent();
> private void btnCustCntSearch_Click(object sender, EventArgs e)
> Session epiSession = new Session("user", "password",
> "AppServerDC://myserver:9031", Session.LicenseType.Default);
> SearchOptions opts = new
> SearchOptions(SearchMode.ShowDialog);
> opts.DataSetMode = DataSetMode.ListDataSet;
> adpCustCnt.InvokeSearch(opts);
I'm not in the office today but I am guessing that the SearchOptions
BO is looking for the number of search items to display by default and
that's stored in the config folder of the client. I would make a copy
of the entire config folder into your debug or release folder. I'm
assuming of course that the program is looking for the config file in
a relative position to the executable.
HTH,
Mark W.
