Hello,
We’ll be using Epicor for two years on April, yet we need to use an interface from our current quotation system into Epicor. We tried to ditch this software, but reality is that it won’t dissapear and it will be upgraded to accomodate to the changes in the company even.
So, even though we managed to create customizations to make the process more intuitive and simple and fast, the fact is that we must now create a full interface between this software and Epicor.
Specifically we are going to create a quote(along other data like customer and some UDs) and the corresponding engineering for each line. All our products are configured.
What would you recommend? Should I go with oData? Or should I stick to WCF?
The quotation software is windows based and we are using Epicor in the same plataform, everything inside an organization so there are no requirements for web based or internet publish.
The idea is that Sales representative will create the quote on this software and click a button to create the corresponding document on Epicor, once it is approved by the customer. So everything will be executed at the windows application.
Thank you
