Crash Protection
Ann,
Under Progress Explorer following the tree expand "localhost", then expand
"Databases". Right click "Properties" on your data base and UNCHECK
"Automatically Start this Database when the Admin Server is Started".
I don't like them starting automatically either. I also like to have TASK
Manager up when I start each database to see how much memory my production
database and training databases eat up when started.
Patrick Winter
sSc Specialty Screw Corporation
Vantage 6.10.514, Progress 9.1D08, Windows 2003 Server, Crystal 8.5.3.975
Sent: Friday, March 11, 2005 9:00 AM
Subject: [Vantage] Re: Crash Protection
(Testing on standalone notebook) I've done a 'Database Purge and Summarize',
twice with Crash Protection off (3 hours) and once with it on (6.5 hours).
Our db is over 4 GB.
I think if I can get the crash protection turned back on before I start the
EPIC50 db, I might have a chance. Problem is that as soon as I connect
localhost in Progress Explorer, it also starts EPIC50 db. I would like to
try to set EPIC50 db to start manually so I can turn crash protection back
on before starting it. I have to connect local host to get to the
configuration settings to make the change, then EPIC50 db starts
automatically before I can make the change.
Thank you for your repsonse. I may have to give up and leave crash
protection on, but I'm not ready to give in yet. I currently need to do a
purge, then dump and load. In the future I will be upgrading from 5.0 to
6.1, so I want to be able to turn the crash protection off if possible, just
need to know the rules.
This notebook is brand new, haven't even used it for anything else yet. I
don't want to rule out the possibility that the notebook has something to do
with the errors I am getting. My errors indicate that I am loosing the
connection to the Admin server on local host:
variety of errors last night: exception errors in the Progress application,
java.mi.ConnectIOException, java.net.NoRouteToHost, Exception:Host
unreachable, java.lang.NullPointer, com.ms.com.ComFailException. In power
settings, I set the monitor to turn off after 15 minutes, and told
everything else (hard drives
etc.) to never turn off.
The error I got in the previous attempts were: First I restored the db,
then started services, the connected localhost in Progress explorer (EPIC50
db automatically starts), turned off crash protection and reconnected in
progress exlorer. Logged into Vantage, ran db purge, it said it completed
successfully, logged out of Vantage, logged into Vantage, logged out of
Vantage, no problems. Disconnected EPIC50 and localhost, stopped admin
service, rebooted, started service, connected localhost (EPIC50 connects
automatically-crash protection was still off). At this point and everytime
I try to start EPIC50 manually I got this error: Error in database startup.
Error in startup of database localhose:20931:epic50. Message 08:57:28
Broker: This process terminated with exit code 1. (8619)
All help is appreciated.
Ann Rohyans
AMFAB
574-264-4431
--- In vantage@yahoogroups.com, "Tracy Blaylock" <tblaylock@f...>
wrote:
> When I upgraded from 5.2 to 6.0 I had one support person tell me
to turn
> it off so it would make the process faster and turn it back on
after you
> get done with the schema changes than when I had to redo my
database the
> next day and I called support a different person told me that I
could
> turn it off to shorten the time but she suggested leaving it on
because
> in all concerns of having something go wrong it would be better.
Plus
> it really didn't take that much more time to leave it on than to
take it
> off.
> Tracy Blaylock
> IT Manager / Accounting Support
> Fulton Industries, Inc.
> Telephone: (419)335-3015 ext. 203
> Fax: (419)337-0708
> From: amfabllc [mailto:amfab@a...]
> Sent: Thursday, March 10, 2005 4:22 PM
> Subject: [Vantage] Crash Protection
> I know that you can turn off 'Crash Protection' during upgrades
and
> other things to make the process faster, however I'm not sure I
> understand exactly when to turn it off and back on, and what all
it
> should be used for. I've been testing with my db copied onto a
> standalone notebook and got into trouble when I didn't have crash
> protection turned back on at the right time (I'm on my third db
> restore). Epicor is helping me and said that I need to have it turned
> on before I start the EPIC50 database in Progress Explorer, which I
> will try this time.
> Anyone know the overall dos and don'ts of Crash Protection?
(Vantage
> version 5.00.329, if it matters).
> My plan is to test this on the standalone notebook first before I
do
> it on the server (hopefully this weekend):
> 1) backup db from server to backup.1 file
> 2) shut down Vantage on server so that nobody can log in
> 3) restore db on notebook
> 4) perform 'Database Purge and Summarize' for Job Details,
Indirect
> Labor and Change Log' (takes 3 hours during test with crash protection
> turned off, db=4.25GB) - completed successfully -
> 5) Restarted notebook, started service, connected local host in
> Progress tool - and tried to start EPIC50 database. This is where
I
> get my error. Epicor says I need to turn crash protection back on
> before starting the database. This is what I am testing now.
> 6) Considering that solves the proglem, I am additionally going
to
> test and perform a dump and load on the notebook over the weekend and
> restore the updated db onto the NT server before Monday.
> 7) As I understand it, I must have crash protection turned on
when
> I start the EPIC50 database. After it is started, I can turn
crash
> protection off -- as long as I turn it back on before I start the
> EPIC50 db in Progress Explorer. Is it that simple? I want to
have
> crash protection turned off during the dump and load (I think),
but
> I need to make sure I understand more about it.
> Thanks in advance!
> Ann Rohyans
> AMFAB
must
> have already linked your email address to a yahoo id to enable
access. )
Builder
> and Crystal Reports and other 'goodies', please goto:
> Yahoo! Groups Links
Yahoo! Groups Links
I know that you can turn off 'Crash Protection' during upgrades and
understand exactly when to turn it off and back on, and what all it
turned on before I start the EPIC50 database in Progress Explorer,
which I will try this time.
Anyone know the overall dos and don'ts of Crash Protection? (Vantage
My plan is to test this on the standalone notebook first before I do
4) perform 'Database Purge and Summarize' for Job Details, Indirect
protection turned off, db=4.25GB) - completed successfully -
Progress tool - and tried to start EPIC50 database. This is where I
6) Considering that solves the proglem, I am additionally going to
and restore the updated db onto the NT server before Monday.
7) As I understand it, I must have crash protection turned on when
I start the EPIC50 database. After it is started, I can turn crash
EPIC50 db in Progress Explorer. Is it that simple? I want to have
crash protection turned off during the dump and load (I think), but
Thanks in advance!
Ann Rohyans
AMFAB
When I upgraded from 5.2 to 6.0 I had one support person tell me to turn
it off so it would make the process faster and turn it back on after you
get done with the schema changes than when I had to redo my database the
next day and I called support a different person told me that I could
turn it off to shorten the time but she suggested leaving it on because
in all concerns of having something go wrong it would be better. Plus
it really didn't take that much more time to leave it on than to take it
off.
Tracy Blaylock
Fax: (419)337-0708
Thanks in advance!
Ann Rohyans
AMFAB
Yahoo! Groups Links
Summarize', twice with Crash Protection off (3 hours) and once with
it on (6.5 hours). Our db is over 4 GB.
start the EPIC50 db, I might have a chance. Problem is that as soon
as I connect localhost in Progress Explorer, it also starts EPIC50
db. I would like to try to set EPIC50 db to start manually so I can
turn crash protection back on before starting it. I have to connect
local host to get to the configuration settings to make the change,
then EPIC50 db starts automatically before I can make the change.
to do a purge, then dump and load. In the future I will be
upgrading from 5.0 to 6.1, so I want to be able to turn the crash
protection off if possible, just need to know the rules.
yet. I don't want to rule out the possibility that the notebook has
something to do with the errors I am getting. My errors indicate
that I am loosing the connection to the Admin server on local host:
application, java.mi.ConnectIOException, java.net.NoRouteToHost,
Exception:Host unreachable, java.lang.NullPointer,
com.ms.com.ComFailException. In power settings, I set the monitor
to turn off after 15 minutes, and told everything else (hard drives
db, then started services, the connected localhost in Progress
explorer (EPIC50 db automatically starts), turned off crash
protection and reconnected in progress exlorer. Logged into
Vantage, ran db purge, it said it completed successfully, logged out
of Vantage, logged into Vantage, logged out of Vantage, no
problems. Disconnected EPIC50 and localhost, stopped admin service,
everytime I try to start EPIC50 manually I got this error: Error in
database startup. Error in startup of database
localhose:20931:epic50. Message 08:57:28 Broker: This process
Ann Rohyans
AMFAB
574-264-4431
to turn
after you
database the
could
because
Plus
take it
> off.
> Tracy Blaylock
> Fax: (419)337-0708
and
it
(Vantage
do
Indirect
I
to
when
crash
have
but
> Thanks in advance!
> Ann Rohyans
> AMFAB
must
access. )
Builder
> Yahoo! Groups Links
