Hello, Group:
Over the last 12-hours our Windows 2008 Server has been running at 100%, the two processes that are causing this spike are both _proapsv.exe
There are currently no task running and the log files are not revealing the culprit. If we restart the app servers, the cpu usage will drop, but after 30-minutes it spikes again.
There are several app servers running that go into a sending mode and then all become available again.
I'm currently waiting for Epicor technical support to respond.
Thanks.
Jose C Gomez
T: 904.469.1524 mobile
On Tue, Jul 7, 2015 at 10:18 AM, sanfranc415@... [vantage] <vantage@yahoogroups.com> wrote:Â<div> <p></p><p><span>Hello, Group: </span></p><p><span><br></span></p><p><span>Over the last 12-hours our Windows 2008 Server has been running at 100%, the two processes that are causing this spike are both _proapsv.exe </span></p><p><span><br></span></p><p><span>There are currently no task running and the log files are not revealing the culprit. If we restart the app servers, the cpu usage will drop, but after 30-minutes it spikes again.  </span></p><p><span><br></span></p><p><span>There are several app servers running that go into a sending mode and then all become available again.  </span></p><p><span><br></span></p><p><span>I'm currently waiting for Epicor technical support to respond.</span></p><p><span><br></span></p><p><span>Thanks. </span></p><p></p> </div> <div style="color:#fff;min-height:0;"></div>
if you think that a Appserver is hitting 100%, you can run progetstack PID. this will create a file in the OE working directory.
open a proenv
>prompt
> progetstack PID
then you can open the file with an editor.
Sent: Tuesday, July 07, 2015 9:23 AM
Subject: [Vantage] Re: CPU usage at 100%
We have several lbi and dbi files that are in excess of 1Gb.
You need to have open edge installed , you have E10?
what you are describing what I used to have when we had bad BPMs that they would get stuck.
Sent: Tuesday, July 07, 2015 9:45 AM
Subject: RE: [Vantage] Re: CPU usage at 100%
Thanks, but it doesn't look like that command is available. Also, the CPU usage is spread over 5-6 different PIDS which use about 10-20 each.
Jose C Gomez
On Tue, Jul 7, 2015 at 1:00 PM, sanfranc415@... [vantage] <vantage@yahoogroups.com> wrote:Â<div> <p>We are still stuck on 10.1B HF33, this is 8.03.408</p><div><br></div><div>There are no BPMs installed or running.</div><div><br></div><div>We did have 1 user recently use the DMT tool, but pretty sure it was to extract data.</div><p></p> </div> <div style="color:#fff;min-height:0;"></div>
Could it be that you have employees not clocking out.
Sent: Tuesday, July 07, 2015 12:36 PM
Subject: Re: [Vantage] Re: CPU usage at 100%
It seems when the employees go to end labor activity in MES it hungs up. This might be what's causing the CPU to hit and stay at 100%.
Run abaq and see how many active activities you have
On Jul 7, 2015 6:02 PM, "sanfranc415@... [vantage]" <vantage@yahoogroups.com> wrote:Â<div> <p>Darn spell checker:Â <div><br></div><div>*Â alleviate not elevate. Â </div><div>Â </div> </div> <div style="color:#fff;min-height:0;"></div>
