Thanks for the feedback. Sounds like I'm SOL for the moment. If I do come up with a solution I will definitely post it.
Drew
Drew
--- In vantage@yahoogroups.com, "Dan Godfrey" <dgodfrey@...> wrote:
> That is exactly it. I did the trace and then looked to duplicate the
> process. The BO.methods shown in the trace are not available through
> customization, either with the oTrans object or the adapter. I just
> found out that Vantage support will not/ can not help with this issues.
> I have not looked into overriding the dll, which is what their
> development team would do for $$.
> Of bw2868bond
> Sent: Thursday, November 05, 2009 4:38 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Count Part by Class
> Have you done a trace to see what Business Objects are being used and
> the Methods called?
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Dan
> Godfrey" <dgodfrey@> wrote:
> > I am working on the exact thing. What I have learned is this:
> > 1) the transaction object in the form does not have a way to add a
> > record to the CountPart dataset.
> > a) there is no Update method in the methods list.
> > b) there is no GetNewCountPart method in the methods list
> > 2) the CountPart Adapter does not have a way to add a record to the
> > CountPart dataset.
> > a) the update method does not allow you to pass in a dataset to
> > update.
> > I have a call in to Vantage and I have not received a return call back
> > yet.
> > I will let you know anything that I learn as it goes, please keep me
> > upto date with anything you learn.
> > Dan
> > From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> Behalf
> > Of drew.pete
> > Sent: Wednesday, November 04, 2009 1:01 PM
> > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > Subject: [Vantage] Count Part by Class
> > I am working on a customization in the Count Group Entry Form which
> > would allow the user to select a group of parts based on their class
> ID.
> > I can get the search button to work to search for the parts and I
> > understand how to take the records returned from the search and write
> > those to a datasource. I am falling down, however, in creating the
> rows
> > in the datasource to dump the information into. Here is the code I
> have
> > thus far...
> > Private Sub btnPartsClass_Click(ByVal Sender As Object, ByVal Args As
> > System.EventArgs) Handles btnPartsClass.Click
> > '// ** Place Event Handling Code Here **
> > Dim recSelected as boolean
> > Dim showSearch as boolean = true
> > Dim whereclause As String = String.Empty
> > Dim multirecords As Boolean = True
> > Dim i as integer
> > Dim edvGroupView As EpiDataView =
> > CType(oTrans.EpiDataViews("groupView"), EpiDataView)
> > Dim GroupID As String =
> > edvGroupView.dataView(edvGroupView.Row)("GroupID")
> > Dim dsSelectParts As DataSet =
> Epicor.Mfg.UI.FormFunctions.SearchFunctions.listLookup(oTrans,"PartAdapt
> > er",recSelected, showSearch, whereClause, multirecords)
> > If (recSelected) Then
> > i = 1
> > Dim PartSelectAdapter As CountPrtAdapter = New
> > CountPrtAdapter(CountControlForm)
> > PartSelectAdapter.BOConnect()
> > while i <= dsSelectParts.Tables(0).Rows.count()-1
> > Dim PartNum As String =
> > PartSelectAdapter.CountPrtData.Tables("CountPrt").Rows(i)("PartNum")
> > PartSelectAdapter.GetNewCountPrt(GroupID)
> > PartNum = dsSelectParts.Tables(0).Rows(i)("PartNum")
> > i = i + 1
> > End While
> > PartSelectAdapter.Dispose()
> > End If
> > End Sub
> > PartNum is not the only field I will be writing to the datasource. I
> > will be adding the others later when I get the structure down. I
> believe
> > I am falling down mostly with my inexperience with GetNewCountPrt. Is
> > this the right function to be using when wanting to write multiple
> > search records returned to a datasource? Thanks in advance for any
> help
> > you can provide.
> > Drew
