Costing
OR...
you can use DMT to do these updates if you have that available.
Brad Boes
Metalworks
--- In vantage@yahoogroups.com, "pbparker" <scrumbus@...> wrote:
> I'd be curious as to what your updates were, I'm considering switching a large amount of our parts manually from standard based to average based, and would be interested in knowing what issues you ran into and what table you needed to modify so I don't miss any.
> --- In vantage@yahoogroups.com, Waffqle <waffqle@> wrote:
> > You can do a mass update on the DB. We did this at our location. It created
> > a few issues here and there, but nothing too major. As long as your
> > financial folks are astute, it shouldn't be earth shattering.
> > You don't need SQL for this. If you want to do it, let me know and I can
> > send you some code to change it.
> > On Thu, Oct 6, 2011 at 2:54 PM, Virginia Joseph <vjoseph@>wrote:
> > > Unfortunately, you are not missing anything. You are correct that you need
> > > to remove all stock, change cost basis then put stock back in. The only way
> > > to avoid this being a manual process is if you are on SQL.
> > > Virginia Joseph
> > > Deep Hole Specialists, LLC
> > > vjoseph@
> > > --- In vantage@yahoogroups.com, "ariffer" <ariffer@> wrote:
> > > > I am running 8.03.403d. Our CFO wants to go from Lot based costing to
> > > Standard costing. I can load standards using the costing workbench, but is
> > > there a good way to change the cost basis? From what i am seeing I will have
> > > to remove all stock change cost basis than put stock back in. I am hoping
> > > there is a trick I am missing.
> > > > thanks,
> > > > Adam
> > *Waffqle Driggers*
> > *High End Dev, System Design, Profit Drinking
> > *:: 904.962.2887*
> > *:: waffqle@*
> > *:: NO FAXES*
Why would a transaction in the Job change the last cost field for the part?
Sam Seitz
Specialist, ERP System
Cardington Yutaka Technologies, Inc.
Tel 419.864.8777, ext. 244
Fax 419.864.7841
Email mailto:sseitz@...
www <http://www.yutakatech.com/> http://www.yutakatech.com/
PRIVATE AND CONFIDENTIAL: The sender intends to communicate the contents of this transmission only to the person to whom it is addressed. This transmission may contain information that is privileged, confidential or otherwise exempt from disclosure under applicable law. If the recipient of this transmission is not the designated recipient or the employee or agent responsible for delivering this transmission to the designated recipient, you are hereby notified that any dissemination or copying of this communication is strictly prohibited. If you have received this transmission in error, please notify me immediately by telephone (419) 864-8777.
what cost is the part on avg/stdn/last?
are you using auto receipt?
is there subcontract operations?
Frank Zeigafuse
Innovative Office Products
General Manager
Direct Phone: 610-559-6369
Email: fzeigafuse@...
Sent: Friday, June 25, 2004 10:48 AM
To: Vantage User Group (E-mail)
Subject: [Vantage] Costing
Sam Seitz
Fax 419.864.7841
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=129tc7nl5/M=295196.4901138.6071305.3001176/D=gr
oups/S=1705007183:HM/EXP=1088265453/A=2128215/R=0/SIG=10se96mf6/*http://comp
anion.yahoo.com> click here
<http://us.adserver.yahoo.com/l?M=295196.4901138.6071305.3001176/D=groups/S=
:HM/A=2128215/rand=888525382>
_____
Yahoo! Groups Links
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
<www.LCDarms.com> -- Ergonomic mounting solutions for monitors and keyboards
This e-mail is from Innovative Office Products, Inc. but expresses the views of the sender and not necessarily the views of the company. The email and any files transmitted with it are confidential to the intended recipient at the e-mail address to which it has been addressed. It may not be disclosed or used by any other than that addressee, nor may it be copied in any way. If received in error, please delete and notify the sender via e-mail or sales@... quoting the name of the sender. Messages sent via this medium may be subject to delays, non-delivery and unauthorized alteration. This e-mail has been prepared using information believed by the author to be reliable and accurate. Unless expressly stated otherwise, this e-mail does not form part of a legally binding contract or agreement between recipient and Innovative Office Products, Inc.
Warning: Although Innovative Office Products, Inc. has taken reasonable precautions to ensure no viruses are present in this email, we cannot accept responsibility for any loss or damage arising from the use of this email or attachments. It is, therefore, your responsibility to scan attachments (if any).
I am running 8.03.403d. Our CFO wants to go from Lot based costing to Standard costing. I can load standards using the costing workbench, but is there a good way to change the cost basis? From what i am seeing I will have to remove all stock change cost basis than put stock back in. I am hoping there is a trick I am missing.
thanks,
Adam
Unfortunately, you are not missing anything. You are correct that you need to remove all stock, change cost basis then put stock back in. The only way to avoid this being a manual process is if you are on SQL.
Virginia Joseph
vjoseph@...
> thanks,
> Adam
> Virginia Joseph
> vjoseph@...
> > thanks,
> > Adam
*Waffqle Driggers*
*:: 904.962.2887*
*:: waffqle@...*
*:: NO FAXES*
> > Virginia Joseph
> > vjoseph@...
> > > thanks,
> > > Adam
> *Waffqle Driggers*
> *:: 904.962.2887*
> *:: waffqle@...*
> *:: NO FAXES*
We basically just change the costing method on the part table and that was
that. I don't recall the particular issues we ran into. If I'm correct, it
was mostly minor accounting issues.
> created
> need
> way
> > > Virginia Joseph
> > > vjoseph@...
> is
> have
> hoping
> > > > thanks,
> > > > Adam
> > *Waffqle Driggers*
> > *:: 904.962.2887*
> > *:: waffqle@...*
> > *:: NO FAXES*
*Waffqle Driggers*
*:: 904.962.2887*
*:: waffqle@...*
*:: NO FAXES*
