Costed method in detail
Does anyone know of a way to find the details of the cost of a method. I can view costs in Method tracker, but I want to know the details of the costs. i.e. How much does each operation cost specifically? How much does each material cost?
I will generally create a “Test” job. Get the info I need and then delete it.
Charlie Smith
CRS Consulting Services
860-919-1708
Can’t you run the BOM cost report to get cost for each components on the BOM? choosing indented BOM when running the report will show all the components on the BOM and their simulated rolled up cost based on Routing hrs and BOM material component costs.
So where in the Test job do you see the details? I can only see the rolled up costs for the job. I need to see what it cost for each operation.
The BOM cost report doesn’t give me enough detail. I need to see what it costs at each operation.
you can run a production detail report to get the estimate cost of the job.
Were you ever able to find what you were looking for? I’m interested in a similar report. We wrote a BAQ, but it seems to me there should be a detail cost report in Epicor.
