That has been the trade off. In order to keep navigation simple, I
would still move the 6.1 database up, just as a read only state.
Bruce Butler
IT Manager
Knappe & Koester, Inc.
_____
Of Paul V. Blais
Sent: Friday, April 27, 2007 11:38 AM
Subject: RE: [Vantage] Cost Roll Ups
If you can go that route I'd probably agree. Put I don't know if you'd
lose all your history and have it tie in. That history and traceability
is key, at least for us.
Behalf
Of Bruce Butler
Sent: Friday, April 27, 2007 11:06 AM
This has been THE sticking point for our movement to 8.03. I am
starting to think starting fresh is not so bad either. We have run into
other issues with the conversions which were painful to get through. It
makes me wonder how many more of these unknowns might crop up. Then
there is the advantage of getting rid of all the old junk (unused part
numbers, mis-configurations, old unused workcenters & machines, etc.
etc.. etc..)
Bruce Butler
IT Manager
_____
Behalf
Of Paul V. Blais
Sent: Friday, April 27, 2007 10:53 AM
We came from 6.0 and we've rebuilt our BOM's. All of our converted
rates have been phased out and were working with new resource groups.
Plus the estimates are correct on production detail reports.
Behalf
Of Stan Chmura
Sent: Friday, April 27, 2007 10:47 AM
Did you start Vantage on 8.803 or did you import 6.1 data? If you've
imported 6.1 data, the whole structure of the BOM costing is changed and
does not convert well. i.e. the costing is off. With the 8.xx testing
I've
done in the last two years, I've determined that if I import 6.1 data, I
will need to rebuild all my BOMs from the ground up. Knowing that,
starting
a fresh database instead of importing 6.1 data doesn't seem quite a
distasteful as originally thought.
_____
Behalf Of
Mark Wonsil
Sent: Friday, April 27, 2007 10:29 AM
PartPlant
record? Did you check the box that says to use Lot Size Costing?
Mark W.
Bruce Butler
IT Manager
_____
Of Paul V. Blais
Behalf
Of Bruce Butler
etc.. etc..)
Bruce Butler
IT Manager
_____
Behalf
Of Paul V. Blais
Behalf
Of Stan Chmura
I've
starting
_____
Behalf Of
Mark Wonsil
> On versions 8.03. Does anyone know why my cost roll ups are coming upAre you amortizing your setup costs with the Lot Costing Qty in the
> with some ridiculous numbers for labor and burden? When I print out a
> production detail report the estimates there are correct, but when I
> view costs on the workbench it's wrong.
PartPlant
Mark W.
