Hi, I would like to known if it is possible, to copy a form layout and added into another form layout.
Can anyone explain how I can do this.
I’m going to make a few assumptions.
I think there was a typo in the version you listed, as 10.5 doesn’t exist yet, and you meant 10.2.500
Since you are third party cloud hosted, you probably don’t have access directly to your report manager. If you do have access to your report manager, then skip all of the below. Just do a save as in Report builder. Or download, rename, and upload your report.
What to do if you don’t have access. Let’s say you want to copy your custom AR Form and make another.
- Report Style > Actions > Copy Report Style.
- Actions > Download Report
- Once you download the report to a local path, browse out to it and drill down to the main RDL file. Right Click and rename it.
- Change the report path/name of your newly copied Report Style to what you just named your new report
- Click on your new report style, and the click Actions > Upload Report. Select the parent folder that contains the “reports” folder that you downloaded previously
