Thank you very much for your reply! Will try this right away.
Matt
--- In vantage@yahoogroups.com, "Mario Aguirre" <maguirre@l...>
wrote:
Matt
wrote:
> Matt,another. I
> There is a command to copy the database from one location to
> only used it once when updating from 5.1 to 5.2. My suggestion isto
> create your test database in Progress Explorer, use the back updatabase.
> generated on line to restore the live database into the test
> You will find out that it is good to have all of the above donefrom the
> beginning because you are going to needed. You need on-line backups and
> you will need a restore to test whenever they ask you to "renew"the
> data.path.
> The command is procopy source target. Provide a complete physical
> Stop the database before using the command. I will consult withEpicor
> prior to do either one.just
> Mario Aguirre
> Lakin General Corporation, Inc.
> From: msgvantage [mailto:bullseye@t...]
> Sent: Monday, April 11, 2005 1:50 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Copy Database?
> Hi all,
> Can someone point me in the right direction to copy our
> production 'mfgsys' database to a testing database?
> It is a new install, so we have no real data to worry about, I
> need to ahve a test db so we're not 'learning' in our productiondb,
> or the training db.don't
> I can copy the SQL DB, and create a new db in progress.. just
> know how to get the schema created to link the two..must
> Thanks,
> Matt
> have already linked your email address to a yahoo id to enableaccess. )
> (1) To access the Files Section of our Yahoo!Group for ReportBuilder
> and Crystal Reports and other 'goodies', please goto:
> Yahoo! Groups Links
> * To visit your group on the web, go to:
> * To unsubscribe from this group, send an email to:
> vantage-unsubscribe@yahoogroups.com
> <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service <http://docs.yahoo.com/info/terms/> .
