Is there a way to copy the entire custom Reports from my live to test without having to do each one, one at a time?
I use a tool called ReportSync, you should check it out. It enables you to move all the contents of a report from one server/folder to another.
There are two ways within ERP to move it using built in functionality. The one where you can move multiples is solution workbench.
~USING SOLUTION WORKBENCH TO EXPORT MODIFIED RDD, STYLE AND SSRS RDL (available in all E10.x):
Here is the KB for which that topic.
https://epicorcs.service-now.com/kb_view.do?sysparm_article=KB0029144#
Guess to be more specific, I am moving this to my test VM, same method and procedure will work, correct?
@Aaron_Moreng’s or the solution I provided will both work for that use case.
Microsoft also has PowerShell utilities for SSRS that we used to migrate reports when spinning up a new test server for 10.2 testing.
Here’s the official GitHub for them: GitHub - microsoft/ReportingServicesTools: Reporting Services Powershell Tools
And a guide I found useful to get started with the process: http://www.sqlservercentral.com/blogs/cláudio-silva/2017/07/12/ssrs-report-deployment-made-easy-700-times-faster/
Not able to access this file from the link.
William - Which file? If it’s on EpicCare (epicorcs.service-now.com/), you’ll have to log in first.
Is it the same login as I would for EpicWeb?
epicweb and epiccare use different credentials.
I ended up using @Aaron_Moreng Method. It was very easy to use and will be a staple in my future upgrades.
Thanks you @aidacra for the info. I was unable to access the link, so I was unable to try your method. However, once I do get in, I will give it a shot as well.
Thanks to everyone for the help.
No problem! Glad it worked.
Please mark that response as the solution so that people can search this answer. Thanks
If you don’t try my method I promise it won’t hurt my feelings :).
I personally, as an IT person managing my work infrastructure, use the solution that @Aaron_Moreng provided internally when I need to move more than a few RDLs from environmentA to envirionmentB and I really don’t want to log into an ERP client
Well, then…
Thanks for the honest info!
I always experience problems with the ReportSync method for custom report. It does not retain the source datasource including the datasource for the customer sub-reports with customer data source path are not maintained even when the destination data source(s) are defined with the same name and path as the source report and sub-report.
I am using ReportSync version 1.1.2.3331
