Does anyone have any steps for converting from avg cost to std cost after go live? Our company wants to switch to standard cost from avg cost but I know there are some things we did before Go Live for std cost coming from avcg cost but are they different after go live?
If you have QOH for a part I know you have to adjust out the quantity before you change the costing method and then adjust it back in, similar to turning on/off lot tracking.
Thank You.
My boss and I were thinking the same
Once you adjust the qty out then you change the parts to std from avg correct? Then you can run the costing workbench.
Do a cost adjustment to set your STD costs on all your purchased parts before running the costing workbench.
Thanks Craig.
