I have a dashboard that has two different queries. Each query has its own tab in the dashboard. The first tab/query has one parameter to enter a specific part number. The second tab/query has 3 parameters non of them is a part number. When I deployed this dashboard clicking on the Generate Application button and then clicking on the deploy button I did not get any errors. But, when I run the dashboard in Kinetic the parameters are all on one side panel which asks for all 4 of the parameters. Is there a way to have it work like it does in Classic? If I run the dashboard in Classic I get only 1 parameter prompt for the first query and 3 for the second query like I always have.
In the Classic UI, one would normally have a Tracker sheet (where your inputs would reside) for each Grid/BAQ. Did your classic dashboard have it this way?
No, the parameters from the BAQ brought up a box for entry.
