I have resized a native epiUltraGrid and have set it initial size (height/width). I have set the Anchor property to top, left, right, bottom so that it should resize itself when form is maximized.
The problem I am facing is that when grid displays on run-time, its size is different than what was set in properties. Also when screen it maximized I am not seeing the horizontal and vertical scroll bars.
There could be some basic settings that I am missing as I am new to Epicor 9 customization.
Yes, grids are tricky, plenty of others have had problems like you describe.
You could try searching for “delete anchor” to find some threads related to grid size/location quirks.
Here is one…
And what I usually do… use the treeview in customization mode to identify the top level container for the grid I’m interested in. I usually have pretty good luck modifying size/positions when I work only at that top level container.
I had success on the Quantity Adjustment screen with the advice from @hkeric.wci - using the Custom XML editor to remove anything that it puts in automatically relating to the grid.
