Control Characters in Calculated Field
Hello all,
I’m trying to set up a barcode that will populate a job number field, tab, then populate a sequence field. I have tried all of the control characters I can look up with ASCII and Code39 however, whenever I scan into a textbox, the control characters are just printed along with the barcode info. Any insight is greatly appreciated.
one problem: Code 3 of 9 doesn’t support a chr(9) (tab) character.
https://www.epiusers.help/t/barcode-scanning-with-dwbar39-in-ssrs-issue/97728/2
If you can swing it, use bartender to generate your barcodes, then you can use a better format to get more fancy stuff.
Or code in parsers into your program and delimit and fill in the stuff programmatically.
Does the solution have to be approached externally from epicor because of the DWBar39 font? From my research, the ASCII characters should be useable with Code39 extended.
I may have completely overlooked some other issue, but it seems if I want to limit the amount of keystrokes for users, I’ll have to incorporate your explained method.
Not necessarily. If you have standardized on a barcode reader, many offer advance options for pre and post scan. They are keyboard emulators, so there are at least limited options.
The following might help
Personally, I went with 2D DataMatrix as you can encode more data into a smaller package including control codes.
Something like this (each op DM will enter into field in MES Report Quantity stopping at the Qty Amount) :
EDIT: Sorry forgot to include the DM output:
