When right-clicking in one job number field on Job Entry I receive these options:
But if I right-click in the number on the top, I get more options:
From the top, it lists the items that have been added in the Context Menu Maintenance, but not in the main job number field. Is there any way to get these items to show from the main job number field?
Looking at the base form as a customization, both fields are tied to JobHeadList.JobNum (top) and JobHead.JobNum (bottom).
Looking at the JobHeadList.JobNum, it is “Like” JobHead.JobNum.
The two in mine are the same, they are just in different menu order. Unless you have customized that form to use a different context menu for the bottom textbox, then they should show the same thing:
