Is there a way to change the “process ID” on a context menu item for all of them at once?
For Example, I want to update the process ID for Customer Entry for all of the context menus where Customer Entry is located, instead of going through each context menu and updating it one by one is there a quicker way for me to do it?
The Context Menu as far as I recall is common across all the instances of that “Like” field. For the right click, you’re specifying which customised version of the screen to open.
True, but all of the different “like” fields point to different process or menu IDs…
What I would like to do is all at once update say the Customer Entry ID across all “Like” fields where it is referenced at once, instead of going through each context menu where customer entry is referenced andmanually and updating it. I would update Customer entry process ID once instead of 200-300 times
