Has anyone added “Context Help” to fields in a form?
Or been able to add “Field Help” to custom columns on forms?
If so, how did you go about it?
You can add to the help file if you have the SDK.
Field Help you can add via UD Column Maintenance, Description field. You may need to be on 10.2 for it to show-up.
Thanks!
Found the Field Description and I believe this will work for what we are trying to do.
Don’t have access to SDK. I’ll ask for it if the above is not enough.
