Does anyone know why on launch of the configurator an error message as below would occur? Able to create the part as normal after continuing with the error message
Application Error
Exception caught in: Erp.Lib.Configurator
Error Detail
Message: Input string was not in a correct format.
Program: Erp.Lib.Configurator.dll
Method: TriggerInputEvent
Client Stack Trace
at Erp.Lib.Configurator.Runtime.ConfigurationController`1.TriggerInputEvent(InputChangedArgs args)
at Erp.UI.Cfg.TEST06fae84c620e411c95a9202dae9793fa.Controllers._USAUSAController._USAUSAPage1_ColumnChanged(Object sender, DataColumnChangeEventArgs e) in c:\Users\ypatel\AppData\Local\Temp\ConfigDump\Client_USAUSAController.cs:line 708
