Hi All,
basically this is this is tha same, we are willing to create a new company but need to know if it is possible to kind of use as template any of the existing companies with AP, AR, GL and Currency setup.
is that possible?
We are considering the use of Epicor for several other legal entities we have and plan to create a new company with in Epicor for each LE
I have several questions on the approach
1 – is there a method that will allow me to setup a new company with UOM, GL… save it as a template and copy into my new company each time I have a new startup?
I can do this with a single company and have the SQL dB saved, but in a multi-company setup, the other companies have active data
2 – in a multi-company setup, can I have more than one GL consolidation allowing me to identify specific companies that will roll into the deferent GLs?
What should I be aware when going down this path, I do hope to stay with a single SQL server to optimize concurrent licensing and to use the DIRECT sync for any global entities I may need (Parts, customers…)
