Communication Error
Anyone know what this means?
ERP10: A communication error occurred trying to run task ID 3322661 for agent SystemTaskAgent on the application server (User: schedule, Task Description: Fill Shop Capacity Records). If this continues to happen investigate if you need to increase the receive and send timeouts in your web.config.
Error Detail:
The socket connection was aborted. This could be caused by an error processing your message or a receive timeout being exceeded by the remote host, or an underlying network resource issue. Local socket timeout was ‘1.00:00:00’.
Stack Trace:
Server stack trace:
at System.ServiceModel.Channels.StreamConnection.Read(Byte[] buffer, Int32 offset, Int32 size, TimeSpan timeout)
at System.ServiceModel.Channels.SessionConnectionReader.Receive(TimeSpan timeout)
at System.ServiceModel.Channels.SynchronizedMessageSource.Receive(TimeSpan timeout)
at System.ServiceModel.Channels.TransportDuplexSessionChannel.Receive(TimeSpan timeout)
at System.ServiceModel.Channels.TransportDuplexSessionChannel.TryReceive(TimeSpan timeout, Message& message)
at System.ServiceModel.Dispatcher.DuplexChannelBinder.Request(Message message, TimeSpan timeout)
at System.ServiceModel.Channels.ServiceChannel.Call(String action, Boolean oneway, ProxyOperationRuntime operation, Object[] ins, Object[] outs, TimeSpan timeout)
at System.ServiceModel.Channels.ServiceChannelProxy.InvokeService(IMethodCallMessage methodCall, ProxyOperationRuntime operation)
at System.ServiceModel.Channels.ServiceChannelProxy.Invoke(IMessage message)
Exception rethrown at [0]:
at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg)
at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type)
at Ice.Contracts.RunTaskSvcContract.RunTask(Int64 ipTaskNum)
at Ice.Proxy.Lib.RunTaskImpl.RunTask(Int64 ipTaskNum) in c:_Releases\ICE\RL3.2.300.0\Source\Shared\Contracts\Lib\RunTask\RunTaskImpl.cs:lin
Did you ever figure this out?
Yes, but I do not remember how. Sorry. I think I called the help desk for assistance.
