Check out this quick 90 second video on what is coming in 2023.1 UI Experience in the browser.
https://players.brightcove.net/2615230543001/25jEmbUWoS_default/index.html?videoId=6322498270112
sending this to our Engineering Dept. I think they’ll love the changes
forward all you want. We want people to know what is coming.
Its the same video I showed last Wednesday… You must not have noticed it then, but your name popped up on the screen.
You’re acting like I wasn’t reeling and unfocused after anxiously giving my presentation just before you. ![]()
Showed this to our “Epicor core team” today in our meeting to gin up the coming changes.
You might want to provide ACTUAL gin as well. ![]()
I’m reviewing the webinar that you did - sneek peek at 2023.1. Am I right in assuming that the changes you’re reviewing are done on the Browser Based forms only? For example, you spent some time talking about changes in Job Entry: moving fields around adding stacked card tabs, etc. If we’re using the client still, will we see these changes there also?
Thanks!
Kevin Simon
if you are in the smart client, but using the new kinetic screens, you WILL see these changes. This is because even if you are in the smart client, it actually launches an embedded browser and retrieves the kinetic screen.
The only “problem” with this is that the embedded browser is not as efficient as when you run this all directly from a web browser, which is the preferred, and best way to run Kinetic.
