ComboBox Search Filter
thanks Joshua
What i used in the end is generating from the wizard a simple search
attached to a combobox and then modified the whereClause to mattch what i
need.
Thanks for the help
On Tue, Aug 6, 2013 at 3:27 PM, Joshua Giese <jgiese@...
> wrote:
> I was mistaken I thought I used BOReader for this but I didn't. The idea
> would be exactly the same except instead of using a list as the datasource
> you would use the returned data from BOReader. None of the delegate inits
> are in here, but hopefully you have a handle on that. Anything you need to
> know about how to use BOReader will already be online here.
> private void cboDown1_ValueChanged(object sender, System.EventArgs
> args)
> try
> string value =
> ((EpiCombo)sender).Value.ToString();
> if (value != "")
> UpdateCboDown2(value);
> catch
> private void UpdateCboDown2(string value)
> //MessageBox.Show(value);
> List<string> list = new List<string>();
> cboDown2.Text = "";
> switch(value)
> case "Art":
> list.Add("Adjust Registration");
> list.Add("Toning Ink");
> cboDown2.DataSource = list;
> cboDown2.Enabled = true;
> break;
> case "Maintenance":
> list.Add("Jam-up");
> list.Add("Paper Break");
> list.Add("Glue +/-");
> list.Add("Cutoff Issue");
> break;
> default:
> cboDown2.Enabled = false;
> break;
> Joshua Giese
> CTO
> 920.437.6400 Ext. 337
> Site ID: 27450-E905700B2-SQL64
> -----Original Message-----
> Of Ephraim Feldman
> Sent: Tuesday, August 6, 2013 12:09 PM
> To: Vantage Yahoo Group
> Subject: Re: [Vantage] ComboBox Search Filter
> Joshua
> Thanks for the response
> Would you mind to elaborate a bit on how you did it and maybe give me a
> example of the code
> I will really appreciate that
> Ephraim
> On Tue, Aug 6, 2013 at 11:26 AM, Joshua Giese <
> jgiese@...> wrote:
> > I used a BOReader on value change and EpiUltraCombo got the data back
> > from the BOReader and set it as the datasource of the second combo
> > Joshua Giese
> > CTO
> > Behalf Of Ephraim Feldman
> > Sent: Tuesday, August 6, 2013 9:06 AM
> > Hi Karen
> > I reviewed that Answerbook already a while back but it only gives a
> > example with a hardcoded search as in "CustNum = 31" but not a dynamic
> > one based on a value in your form
> > I need to filter based on the customer value in the order entry form
> > Ephraim
> > On Tue, Aug 6, 2013 at 9:36 AM, Karen Schoenung <
> > kschoenung@...> wrote:
> > > 4492ESC is from EpicWeb and shows an example...There probably is
> > > something in the tools book too (ICE).
> > > Sent: Tuesday, August 06, 2013 8:26 AM
> > > Subject: [Vantage] ComboBox Search Filter
> > > Hi All
> > > I am trying to crate a ComboBox that will show a filtered list based
> > > on another value on the screen but no success
> > > I want to get something like the contact combo on the order entry
> > > that shows all contacts based on the customer selected .
> > > I tied putting in the SearchValue property CustNum =
> > > OrderHed.CustNum but i am getting a error "invalid query" when i try
> to retrieve data.
> > > Maybe there is a other way to achive that?
> > > thanks
> > > Ephraim
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> > have already linked your email address to a yahoo id to enable access.
> > (1) To access the Files Section of our Yahoo!Group for Report Builder
> > and Crystal Reports and other 'goodies', please goto:
> > http://groups.yahoo.com/group/vantage/files/.
> > http://groups.yahoo.com/group/vantage/messages
> > (3) To view links to Vendors that provide Vantage services goto:
> > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
Hi All
I am trying to crate a ComboBox that will show a filtered list based on
I want to get something like the contact combo on the order entry that
I tied putting in the SearchValue property CustNum = OrderHed.CustNum but i
am getting a error "invalid query" when i try to retrieve data.
thanks
Ephraim
4492ESC is from EpicWeb and shows an example...There probably is something in the tools book too (ICE).
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Ephraim Feldman
Hi All
thanks
Ephraim
Hi Karen
I reviewed that Answerbook already a while back but it only gives a example
with a hardcoded search as in "CustNum = 31" but not a dynamic one based on
Ephraim
> Of Ephraim Feldman
> Hi All
> thanks
> Ephraim
Joshua Giese
CTO
Of Ephraim Feldman
Hi Karen
example with a hardcoded search as in "CustNum = 31" but not a dynamic one
Ephraim
> Hi All
> but i am getting a error "invalid query" when i try to retrieve data.
> thanks
> Ephraim
Joshua
example of the code
Ephraim
> Joshua Giese
> CTO
> Of Ephraim Feldman
> Hi Karen
> Ephraim
> > Hi All
> > thanks
> > Ephraim
args)
try
string value =
if (value != "")
catch
cboDown2.Text = "";
switch(value)
case "Art":
break;
case "Maintenance":
list.Add("Jam-up");
break;
default:
break;
Joshua Giese
CTO
Of Ephraim Feldman
Joshua
example of the code
Ephraim
> Joshua Giese
> CTO
> Hi Karen
> Ephraim
> > Hi All
to retrieve data.
> > thanks
> > Ephraim
