Column width Blank Title 61839
Temporarily assign your SQL accessed field data to appropriate type UD fields - ideally (to minimize code) using unused UD fields in a table already available in the app you are customizing.
Set your ultragrid equal to the newly assigned UD field records.
Dependant upon the app being customized, determine a reliable event trigger to clear your SQL accessed data from the UD fields when closing a record (or list of records).
If it isn't a problem for the UD fields to retain the SQL accessed data (since it will be reupdated the next time your app opens the record), don't bother with the last step of clearing the values before closing.
Rob Brown
Versa Products
Bill Wu <billw@...> wrote:
Thank you for the help. I just tried it and it did not work. I think the
problem is I did not use Epicor's EpidataView as the data source. I set up a
SQL connection in the script editor and get my data from outside of Vantage.
I was hoping I can use code to do that. Any idea? Thanks again.
_____
Kersten MacLennan
Sent: Monday, January 14, 2008 4:45 PM
Subject: RE: [Vantage] Column width
Go into developer mode, pull up the form, adjust the column width, open
the customization, click on the Ultra Grid, then click the Apply button
Kersten MacLennan
IT/ERP Analyst
Semrock, Inc.
3625 Buffalo Rd.,
Suite 6
Rochester, NY 14624
585-594-7009
585-594-7095 fax
kmaclennan@semrock. <mailto:kmaclennan%40semrock.com> com
The Standard in Optical Filters for Biotech & Analytical Instrumentation
Hundreds of Thousands of Ion Beam Sputtered filters delivered -
extensive inventory now!
The information contained in this message and any attachments may be
privileged, confidential, and protected from disclosure. If the reader
of this message is not the intended recipient, or any agent responsible
for delivering this message to the intended recipient, you are hereby
notified that any dissemination, distribution, or copying of this
communication may be unlawful and therefore strictly prohibited. If you
received this message in error, please reply to the message and delete
it. Thank you
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
Behalf
Of Bill Wu
Sent: Monday, January 14, 2008 4:30 PM
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
Subject: [Vantage] Column width
Can someone tell me how to control the column width of UltraGrid. Can I
use
code to do it? I tried
ugdOrders.Columns(0).Width = 60
It gave an error and won't work. Thanks in advance.
Looking for last minute shopping deals? Find them fast with Yahoo! Search.
Can someone tell me how to control the column width of UltraGrid. Can I use
Kersten MacLennan
IT/ERP Analyst
Semrock, Inc.
3625 Buffalo Rd.,
Suite 6
Rochester, NY 14624
585-594-7009
585-594-7095 fax
kmaclennan@...
it. Thank you
Of Bill Wu
use
_____
Kersten MacLennan
Kersten MacLennan
IT/ERP Analyst
Semrock, Inc.
3625 Buffalo Rd.,
Suite 6
Rochester, NY 14624
585-594-7009
585-594-7095 fax
it. Thank you
Behalf
Of Bill Wu
use
