I have a custom dashboard made out of a couple BAQ’s.
In the BAQ I have a couple UD fields. In Dashboard Maintenance I see all the UD fields, while testing under the deploy action I see the fields, but after I deploy the dashboard one of the UD fields is not showing. No header or anything. The one that is not showing is an integer up to 8 digits.
I looked at UD Column Maintenance and it says Table and Data Model are in Sync.
Is there anything else I should be looking at to find out why it is not showing when deployed?
Is this an existing dashboard that you have used? If so it could be a caching issue. Try clearing your cache. If that doesn’t work, make sure you don’t have any personalizations saved for the form (Revert to base).
You were right. For some reason the customization used by default hides it, but when I load Base, it looks right. So i need to fix the customization.
Thanks for the input!
