Column PartNum is constrained to be unique. Value is alredy present Error
Hello
Receiving this error when using Paste Insert in Post Part Filter in Costing Workbench Form. I have share the screenshot along with this. I also tried using Company and PartNum still it give error when selecting multiple part.
If doing Paste Insert for 1 Part then error not coming but its showing blank record.
There is no quick search, no customization still its giving error…tried but no luck
Also, new button is disable for this search. I though clicking new button and then trying Paste Update but it didn’t work that also.
Request if any way , kindly let me know.
thank you very much in advance
You may want to show us your excel data that you are copying from. In addition to that, you can try searching for a single part first and select it, then proceed to paste insert to see if it works. You can delete that first line if it is not required later on. Please also ensure that the partnumber comes with description in your excel data.
Hello Chun Kit,
If I Paste Insert single part, then its showing as blank and if multiple part then its giving error.
Same error was giving in Stock Status Report…but after adding Company also then it got work in this report but same i tried in Costing Workbench – Post form screen but its giving this error.
So I am not getting whats exactly is the issue for this only form.
Have you perhaps tried what I mentioned above?
Hello
Yes. I tried what you had mentioned. I selected parts and then tried to do Paste Insert along with description, but its displaying blank record as mentioned earlier. In excel file its PartNum, PartDescription only.
