You could also try customizing the MES screen.
Below is an .exe code I put together using Visual Studio 2013 and importing epicor's BO into visual studio. This exe is run as a job in SQL set for specific day and time. Therefore, inside of epicor, you could get the reference of a control and disable or enable that control based on time. Yes very doable via customization inside of Epicor if you know how to code it.
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using Epicor.Mfg.BO;
using Epicor.Mfg.Core;
namespace ClockOutUser
class Program
Session epiSession = new Session(
"UserID", "Password",
"AppserverDC://TGI-EPICORAPP:9411",
Epicor.Mfg.Core.Session.LicenseType.Default);
bool morePages = false;
string empID = "StartEnd";
static void Main(string[] args)
Program cou = new Program();
cou.ClockOutEpicorUser();
public void ClockOutEpicorUser()
using (epiSession)
EmpBasic empB = new EmpBasic(epiSession.ConnectionPool);
Labor lbr = new Labor(epiSession.ConnectionPool);
empB.ClockOut(ref empID);
lbr.GetRows("EmployeeNum = 'startend' and ActiveTrans = yes BY EmployeeNum", "", "", "", "", "", "", "", "", "", "", "", 0, 0, out morePages);
