All, we have an issue where our “shop warning” code 180 and 190 that deal with bad clock in/out times are now not showing up on our labor edit report after we just went live with our V8 to E9 conversion. I’ve verified all of the “Alert Group” settings are exactly identical in 9 as was in 8 and that the “show in labor edit” tickboxes are checked on both of those alert codes (180 and 190). We had a consultant look at it and he found that we do NOT have time or expense enabled in our licensing. Time/Expense licensing didn’t exist with Vantage 8, we just had “data collection”. He thinks that has something to do with the problem. He told us that “by default” if we have the production module, we should have had “at leat” the time module enabled when they re-did our license. We have the payroll module (though we don’t use it) enabled. Can anyone tell me if their codes work if we DON’T have time/expense enabled? Has anyone else experienced this kind of problem…
Best regards
Mike Abell
IT Manager
Flexial Corporation
a company of BOA Group
1483 Gould Drive, Cookeville, TN 38506, USA
Phone: +1 931 432 8408
Fax: +1 931 432 1889
Mail: mabell@...
Website:
http://www.flexial.com
http://www.boagroup.com
Â<div> <p>
All, we have an issue where our “shop warning†code 180 and 190 that deal with bad clock in/out times are now not showing up on our labor edit report after we just went live with our V8 to E9 conversion. I’ve verified all of the “Alert Group†settings are exactly identical in 9 as was in 8 and that the “show in labor edit†tickboxes are checked on both of those alert codes (180 and 190). We had a consultant look at it and he found that we do NOT have time or expense enabled in our licensing. Time/Expense licensing didn’t exist with Vantage 8, we just had “data collectionâ€. He thinks that has something to do with the problem. He told us that “by default†if we have the production module, we should have had “at leat†the time module enabled when they re-did our license.   We have the payroll module (though we don’t use it) enabled.   Can anyone tell me if their codes work if we DON’T have time/expense enabled? Has anyone else experienced this kind of problem…
Â
Best regards
Mike AbellIT Manager
Flexial Corporation
Phone:Â Â Â +1 931 432 8408
Fax:Â Â Â Â Â Â Â +1 931 432 1889
Mail:Â Â Â Â Â Â Â mabell@...
Website:Â http://www.flexial.com
              http://www.boagroup.comÂ
<p></p></div> <div style="color:rgb(255,255,255);min-height:0px;"></div>
Sarah Vareschi ▪ Systems ManagerÂ
Â
NyproMold, Inc.
144 Pleasant St, Clinton, MA 01510 ▪ www.nypromold.com Â
D 978.368.4718Â â–ª F 978.365.4548
Â
Â
Â
This e-mail may contain information which is
confidential or privileged. The information is intended to be for the use of
the individual or entity named above. If you are not the intended
recipient, be aware that any disclosure, copying, distribution or use of the
contents of this e-mail is prohibited. In the event of any error in
transmission, unauthorized recipients are requested to contact the sender
immediately and not to disclose or make use of this information. No
employee or agent is authorized to conclude any binding agreement on behalf of
NyproMold with another party by email without express written confirmation by
NyproMold Offices.
P Please consider the environmental impact of
printing this e-mail.
Sarah, thanks….We actually used it daily in Vantage 8 to find bad clock ins/outs….We do NOT have time/expense entry however licensed…..I’m guessing it’s not a license thing as the consultant suggested though….That helps…..Anyone else noticed this behavior in Epicor9. Any fix?????
Sent: Friday, February 05, 2016 9:43 AM
To: Vantage List
Subject: Re: [Vantage] Clock in late / Clock out early shop warning notes on Labor Edit report quit working after upgrade from Vantage 8 to Epicor 9
we use time/expense entry and have the warning messages turned on and I just tested it and they are not showing on our report either. Never noticed before bc we do not use the epicor labor edit report. (I verified we had the employee cloekd out early one active and set to print on the labor edit then ran the labor edit for one of my guys who I know left early this week - no message showed). Not sure if there's another setting somewhere for it since we don't use it (we used to use it on vantage 5 but when we upgraded to 9 we began using dashboards for pretty much everything...)
On Fri, Feb 5, 2016 at 9:53 AM, Mike Abell mabell@... [vantage] <vantage@yahoogroups.com> wrote:
Best regards
Flexial Corporation
Mail: mabell@...
Website: http://www.flexial.com
Sarah Vareschi â–ª Systems Manager
NyproMold, Inc.
144 Pleasant St, Clinton, MA 01510 â–ª www.nypromold.com
D 978.368.4718 â–ª F 978.365.4548
This e-mail may contain information which is confidential or privileged. The information is intended to be for the use of the individual or entity named above. If you are not the intended recipient, be aware that any disclosure, copying, distribution or use of the contents of this e-mail is prohibited. In the event of any error in transmission, unauthorized recipients are requested to contact the sender immediately and not to disclose or make use of this information. No employee or agent is authorized to conclude any binding agreement on behalf of NyproMold with another party by email without express written confirmation by NyproMold Offices.
P Please consider the environmental impact of printing this e-mail.
Sarah,
Care to share with me how to make a dashboard that would show labor entry bad clock in/out times???
To: Vantage List
Best regards
Flexial Corporation
Mail: mabell@...
NyproMold, Inc.
