Excellent. That was exactly what I was looking for! Thanks!
Matt
Matt
--- In vantage@yahoogroups.com, Ken Williams <ken@...> wrote:
> Update the default.mfgsys in the c:\client803\client\config folder. There are two(?) references to server name that you can change, one is the update server and the other is the data server. Generally these are the same. It's just a text file so you can use notepad for the update, then distribute this small file to all the other PC's.
> Ken
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of vistapdmmatt
> Sent: Thursday, May 21, 2009 10:35 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Client PC after moving server
> For Vantage\Vista 8.03.407c...
> I'm curious to know if there is an easy way to update the client PCs after moving Vantage\Vista 8 from one server to another.
> Do I just reinstall the client, or is there a config file that can be updated and copied to all PCs?
> Thanks,
> Matt
