There have been times I have needed to open up an XLS file or process a BAQ grid in a client module to process some data. I realize that there are other tools (DMT, BPM, SC, etc.) to get jobs done so not really looking for other avenues…just learning about client side processing.
Whether I am calling updatable BAQ’s or objects/methods, during the iteration process it locks up the epicor session while processing. Is there a way to avoid this with some kind of multi-threading option or is this the way Epicor client processing works and the best approach is two sessions for these circumstances?
I assume the task you’re trying to accomplish is to free up the UI thread. I’ve done this utilizing a client customization and an old school BackgroundWorker class in a custom form. Not sure if it is exactly what you’re asking but maybe it will help a little
// Custom code for UD01Form
// Created: 6/1/2018 12:10:31 PM
using System;
using System.ComponentModel;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using Ice.BO;
using Ice.UI;
using Ice.Lib;
using Ice.Adapters;
using Ice.Lib.Customization;
using Ice.Lib.ExtendedProps;
using Ice.Lib.Framework;
using Ice.Lib.Searches;
using Ice.UI.FormFunctions;
using Infragistics.Win.UltraWinToolbars;
using Infragistics.Win.UltraWinGrid.ExcelExport;
using Ice.Proxy.Lib;
using Ice.Core;
using Ice.Tablesets;
using System.Collections;
using System.Text;
using System.Linq;
public class Script
DataTable dtInput = new DataTable();
private EpiDataView edvInput;
private StringBuilder builder;
private BackgroundWorker worker;
private System.Windows.Forms.ProgressBar pbProgress;
private int totalRecCount = 0;
this.grdInput.InitializeLayout += new Infragistics.Win.UltraWinGrid.InitializeLayoutEventHandler(this.grdInput_InitializeLayout);
this.btnProcesss.Click += new System.EventHandler(this.btnProcesss_Click);
this.btnClear.Click += new System.EventHandler(this.btnClear_Click);
dtInput.Columns.Add("Donor",typeof(string));
dtInput.Columns.Add("OPO Name", typeof(string));
dtInput.Columns.Add("OPO Donor Number", typeof(string));
edvInput = new EpiDataView();
edvInput.dataView = dtInput.DefaultView;
oTrans.Add("edvInput", edvInput);
grdInput.EpiAllowPaste = true;
grdInput.EpiAllowPasteInsert = true;
//grdInput.InsertNewRowAfterLastRow = true;
builder = new StringBuilder();
SetUpPB();
this.worker = new BackgroundWorker();
this.worker.DoWork += new DoWorkEventHandler(this.worker_DoWork);
this.worker.ProgressChanged += new ProgressChangedEventHandler(this.worker_ProgressChanged);
this.worker.RunWorkerCompleted += new RunWorkerCompletedEventHandler(this.worker_RunWorkerCompleted);
this.worker.WorkerReportsProgress = true;
this.worker.WorkerSupportsCancellation = false;
this.grdInput.InitializeLayout -= new Infragistics.Win.UltraWinGrid.InitializeLayoutEventHandler(this.grdInput_InitializeLayout);
this.btnProcesss.Click -= new System.EventHandler(this.btnProcesss_Click);
this.btnClear.Click -= new System.EventHandler(this.btnClear_Click);
// Begin Custom Code Disposal
// End Custom Code Disposal
pbProgress.Dispose();
pbProgress=null;
this.worker.DoWork -= new DoWorkEventHandler(this.worker_DoWork);
this.worker.ProgressChanged -= new ProgressChangedEventHandler(this.worker_ProgressChanged);
this.worker.RunWorkerCompleted -= new RunWorkerCompletedEventHandler(this.worker_RunWorkerCompleted);
private void SetUpPB()
pbProgress = new System.Windows.Forms.ProgressBar();
//Draw a textbox where you'd like the PB to be and get its Location from there then remove textbox
pbProgress.Location = new System.Drawing.Point(14, 335);
pbProgress.Name = "pbProgress";
//Draw a TextBox where you'd like the PB to be and get its Size from there then remove textbox
pbProgress.Size = new System.Drawing.Size(688, 20);
//Get a Hold of the Parent Container where you'd like the PB to be
Ice.UI.App.UD01Entry.DetailPanel pnl =(Ice.UI.App.UD01Entry.DetailPanel)csm.GetNativeControlReference("d5488fbc-e47b-46b6-aa3e-9ab7d923315a");
//Add PB to the above container
pnl.Controls.Add(pbProgress);
private void UD01Form_Load(object sender, EventArgs args)
// Add Event Handler Code
// Hide Native Toolbar Controls
baseToolbarsManager.Tools["NewTool"].SharedProps.Visible=false;
baseToolbarsManager.Tools["RefreshTool"].SharedProps.Visible=false;
baseToolbarsManager.Tools["DeleteTool"].SharedProps.Visible=false;
baseToolbarsManager.Tools["SaveTool"].SharedProps.Visible=false;
baseToolbarsManager.Tools["EditMenu"].SharedProps.Visible=false;
baseToolbarsManager.Tools["HelpMenu"].SharedProps.Visible=false;
baseToolbarsManager.Tools["ToolsMenu"].SharedProps.Visible=false;
baseToolbarsManager.Tools["ActionsMenu"].SharedProps.Visible=false;
baseToolbarsManager.Tools["FileMenu"].SharedProps.Visible=false;
baseToolbarsManager.Tools["AttachmentTool"].SharedProps.Visible=false;
baseToolbarsManager.Tools["ClearTool"].SharedProps.Visible=false;
baseToolbarsManager.Tools["CopyTool"].SharedProps.Visible=false;
baseToolbarsManager.Tools["CutTool"].SharedProps.Visible=false;
baseToolbarsManager.Tools["PasteTool"].SharedProps.Visible=false;
baseToolbarsManager.Tools["UndoTool"].SharedProps.Visible=false;
baseToolbarsManager.Tools["PrimarySearchTool"].SharedProps.Visible=false;
dtInput.Clear();
txtProgress.Text = builder.ToString();
private void grdInput_InitializeLayout(object sender, Infragistics.Win.UltraWinGrid.InitializeLayoutEventArgs args)
grdInput.InsertNewRowAfterLastRow = false;
private void worker_DoWork(object sender, DoWorkEventArgs e)
//sender is BackgoundWorker
//this is where the background operation goes
using(UD100Adapter adapterUD100 = new UD100Adapter(oTrans))
adapterUD100.BOConnect();
builder.Append("Start Process...").AppendLine();
//foreach(DataRow dr in dtInput.Rows)
for(int i = 0; i<dtInput.Rows.Count; i++)
var dr = dtInput.Rows[i];
string whereClause = string.Format("Key1 like '{0}-%'", dr["Donor"].ToString());
//start log
builder.Append(string.Format("Looking up Donor {0}...", dr["Donor"].ToString())).AppendLine();
//the Hashtable stores the runtime search criteria
System.Collections.Hashtable wcs = new Hashtable(1);
wcs.Clear();
wcs.Add("UD100", whereClause);
Ice.Lib.Searches.SearchOptions opts = Ice.Lib.Searches.SearchOptions.CreateRuntimeSearch(wcs, Ice.Lib.Searches.DataSetMode.RowsDataSet);
adapterUD100.InvokeSearch(opts);
int rowCount = adapterUD100.UD100Data.UD100.Rows.Count;
if(rowCount>0)
foreach(DataRow udRow in adapterUD100.UD100Data.UD100.Rows)
//modify here
udRow.BeginEdit();
udRow["Character04"] = dr["OPO Name"];
udRow["Character05"] = dr["OPO Donor Number"];
udRow["RowMod"] = "U";
udRow.EndEdit();
//update log
builder.Append(string.Format("{0}: Success!", udRow["Key1"].ToString())).AppendLine();
totalRecCount++;
//update
adapterUD100.Update();
worker.ReportProgress(i);
else
//update log
builder.Append(string.Format("******Failed to find UD100 recs for {0}******", dr["Donor"].ToString())).AppendLine();
adapterUD100.Dispose();
worker.ReportProgress(100);
private void worker_ProgressChanged(object sender, ProgressChangedEventArgs e)
//notifies progress bar when changed
pbProgress.Value = e.ProgressPercentage;
private void worker_RunWorkerCompleted(object sender, RunWorkerCompletedEventArgs e)
//On completed, do the appropriate task
if(e.Error !=null)
MessageBox.Show("Error while performing tasks!");
else
MessageBox.Show(string.Format("Complete. {0} records updated!", totalRecCount.ToString()));
//re-enable the UI interface to prevent weird threading issues
btnProcesss.ReadOnly = false;
btnClear.ReadOnly = false;
private void btnProcesss_Click(object sender, System.EventArgs args)
if (dtInput.Rows.Count>0)
try
worker.RunWorkerAsync();
builder.Clear();
pbProgress.Value = 0;
totalRecCount = 0;
btnProcesss.ReadOnly = true;
btnClear.ReadOnly = true;
catch(Exception ex)
MessageBox.Show(ex.Message);
else
MessageBox.Show("Add Inputs");
private void btnClear_Click(object sender, System.EventArgs args)
dtInput.Clear();
builder.Clear();
txtProgress.Text = string.Empty;
totalRecCount = 0;
