Client install problems - Critical Error message
Browse to your server, and copy the "client" folder from your Epicor905
share to the location you installed the client on the workstation.
That usually fixes any problems with a client installation.
Brian Roberts
Sent: Friday, April 08, 2011 2:37 PM
Subject: [Vantage] Client install problems - Critical Error message
I am getting an error in one client install, for Epicor 9.05.603. All other
client installs are working fine, and I can't find anything unusual about
this machine. Various details below, and I'm hoping that somebody has seen
this before and can point me in the right direction.
After the install, the normal Auto Update ran. Starting Epicor (normal
interface) gives the splash screen for a couple seconds, then says "Critical
Error" (and nothing else) and shuts down. However, the MES interface works
fine! The machine is Windows XP SP3, all windows updates installed. Other
installed software is the normal boring stuff (office etc), the same
software in use on dozens of other machines in the office where Epicor is
working fine. Tried un-install & re-install, no change in symptoms.
Error Detail
Critical error
Stack Trace
at System.Management.ThreadDispatch.Start()
at System.Management.ManagementScope.Initialize()
at System.Management.ManagementEventWatcher.Initialize()
at System.Management.ManagementEventWatcher.Start()
at Epicor.Mfg.Lib.NetworkMonitor.watchEvent(String eventName)
at Epicor.Mfg.Lib.NetworkMonitor.Start()
at Epicor.Mfg.UI.Suspend..ctor(Form mainForm, Session session)
at Epicor.Mfg.UI.MenuForm.loadUserSettings(String userID)
at Epicor.Mfg.UI.MenuForm.SetupComponent()
at Epicor.Mfg.UI.App.Launch.ShowMenuForm()
at Epicor.Mfg.UI.App.Launch.ShowDialog(String[] args)
Brian Roberts
Business Systems Analyst
Ground Effects Ltd
other client installs are working fine, and I can't find anything
unusual about this machine. Various details below, and I'm hoping that
somebody has seen this before and can point me in the right direction.
"Critical Error" (and nothing else) and shuts down. However, the MES
interface works fine! The machine is Windows XP SP3, all windows
updates installed. Other installed software is the normal boring stuff
(office etc), the same software in use on dozens of other machines in
the office where Epicor is working fine. Tried un-install & re-install,
Error Detail
Critical error
Stack Trace
Brian Roberts
Ground Effects Ltd
