Clear client cache (E10)
There are two ways I know to clear the cache in 10.0.700.4. Both require you to be at the user's work station, though.
The first is, in Epicor, go to Settings, then click "Clear Client Cache".
The second is a manual method.
Go to C:\Program Data\Epicor\<server name>
Delete the folder that is named after your server and this will manually rebuild when you reopen Epicor.
I'm wondering if anyone has an easy solution to clearing client cache?
Anytime I update code on a form or make changes to a dashboard I either need to delete their Epicor program data or clear their cache.  I don't know if there are any options to periodically clear cache or if I have to setup a scheduled task to clear out the Epicor program data.  It seems to be a constant problem since I upgraded our company to E10.  On 905 I was able to just tell the user to close and open Epicor.  This no longer is the case.
Any ideas?
What version are you running?  We are running 10.0.700.1 and also see this problem.  I asked Rich Riley at Insights last year about it and he said if we are having that issue, we should upgrade to current version (at that time it was 10.0.700.4).
Tanner
I'm on 700.4, still an issue.
